Ir para o conteúdo principal
Kindle 7th Generation Back Panel Replacement
O que você precisa
    1. Kindle 7th Generation Back Panel Replacement, Front Panel: passo 1, imagem 1 %32 Kindle 7th Generation Back Panel Replacement, Front Panel: passo 1, imagem 2 %32
      • Power off your Kindle before beginning disassembly.
      • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
      • Run the tool along the seams to pry open the front panel.
      Pergunte ao FixBot
      Comentar
    2. Kindle 7th Generation Back Panel Replacement: passo 2, imagem 1 %32
      • Peel the front panel off to remove it from the Kindle.
      • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
      • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
      • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
      Pergunte ao FixBot
      Comentar
    1. Kindle 7th Generation Back Panel Replacement, Back Panel: passo 3, imagem 1 %32 Kindle 7th Generation Back Panel Replacement, Back Panel: passo 3, imagem 2 %32
      • Remove the ten 5.0 mm T5 Torx screws.
      • A magnetized screw mat can help you keep track of your screws.
      Pergunte ao FixBot
      Comentar
    2. Kindle 7th Generation Back Panel Replacement: passo 4, imagem 1 %32
      • Working evenly along the corners and edges, separate the internal contents from the back panel.
      • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Abby Roulier
Membro desde: 02/08/15
1.167 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 6-28, Amido Winter 2015 Membro de Cal Poly, Team 6-28, Amido Winter 2015
CPSU-AMIDO-W15S6G28
4 Membros
Autoria de 26 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 25
Últimos 30 dias: 89
Ao todo: 6,363
