Introdução
Replacing the battery on your Kindle 2 is fairly simple. It only requires removing the back cover and a few screws.
O que você precisa
Lay the Kindle face down on a soft cloth to protect its screen.
Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
Slide the gray plastic top piece away from the Kindle's metal casing.
Once the gray plastic top piece is detached from the metal back cover, remove it.
42 outras pessoas executaram este guia.
9Comentários do guia
I followed this guide, without changes, and was able to successfully swap a battery on a Kindle DX. The DX is essentially a Kindle 2 with a larger screen.
Thanks, easy and went well!
Maybe you need a thinner spudger, TH?
Easy! Worked well with the tools described. Kudos for making this available, it gave my old Kindle a new breath of life!
Easiest replacement I've done. Thanks!
An ebay-acquired battery fit perfectly, but failed to reboot the kindle or accept a charge.
the battery looks idential to the Kindale battery to an old analog voltmeter.
I conformed that the kindle terminals were receiving battery voltage.
The replacement guide was just fine, Back to the original battery, which is well past its best-by date!
