Introdução
If you discover any issues such as quickly draining battery, freezing, overheating, or charging problems, this could indicate that you need to replace your battery. Through using this guide, you can learn the proper way to conduct a battery replacement for the Kindle 10.
O que você precisa
Gently use a metal spudger to pry, twist, and lift the bezel away from the display.
2Comentários do guia
Do you have any replacements if we break the case ?
The affiliate-linked battery is incorrect. Don’t make the mistake I made. Do not purchase it.
