Ir para o conteúdo principal
Keyboard replacement on a why! W253EU
O que você precisa
  1. Keyboard replacement on a why! W253EU, Battery from why! Remove W253EU: passo 1, imagem 1 %32 Keyboard replacement on a why! W253EU, Battery from why! Remove W253EU: passo 1, imagem 2 %32 Keyboard replacement on a why! W253EU, Battery from why! Remove W253EU: passo 1, imagem 3 %32
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. Keyboard replacement on a why! W253EU, Keyboard: passo 2, imagem 1 %32 Keyboard replacement on a why! W253EU, Keyboard: passo 2, imagem 2 %32 Keyboard replacement on a why! W253EU, Keyboard: passo 2, imagem 3 %32
    • Use a Phillips # 1 screwdriver to remove the two screws located in the slot of the accumulator.
    • Insert a standard screwdriver into the slot in the cover above the keyboard.
    • Lift the cover with the usual care.
  3. Keyboard replacement on a why! W253EU: passo 3, imagem 1 %32 Keyboard replacement on a why! W253EU: passo 3, imagem 2 %32 Keyboard replacement on a why! W253EU: passo 3, imagem 3 %32
    • Use a Phillips # 1 screwdriver to remove the four screws securing the keyboard in the upper part.
  4. Keyboard replacement on a why! W253EU: passo 4, imagem 1 %32 Keyboard replacement on a why! W253EU: passo 4, imagem 2 %32
    • Turn the keyboard towards the screen.
    • Carefully remove the connection cable in the direction of the plug axis.
Conclusão
For reassembly, follow the instructions in reverse order.
Um agradecimento especial a esses tradutores:
de en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Felice Suglia
Membro desde: 06/15/13
31.100 Reputação
Autoria de 264 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 475
