Ir para o conteúdo principal
Keyboard Keyswitch Replacement How To
  1. Keyboard Keyswitch Replacement How To, Step 1: Grab the tool shown in the image: passo 1, imagem 1 %32
    • First you are gonna want to grab a keycap puller/remover.
    Pergunte ao FixBot
    Comentar
    • Do what the video depicts. Pull of the keycap with the keycap remover
    Pergunte ao FixBot
    Comentar
  2. Keyboard Keyswitch Replacement How To, Step 3: Grab the Other Tool: passo 3, imagem 1 %32
    • Grab the keyswitch remover shown in the image.
    Pergunte ao FixBot
    Comentar
  3. Keyboard Keyswitch Replacement How To, Step 4: Locate the Grooves: passo 4, imagem 1 %32
    • There are 2 grooves on the sides of the keyswitch. Your keyswitch will still be in the keyboard, but I took mine out to show them closer.
    Pergunte ao FixBot
    Comentar
    • Grab the 2 grooves with the keyswitch remover like I did. It is important you pull straight up otherwise you could damage our break the pin, which is bad. It may require some force.
    Pergunte ao FixBot
    Comentar
  4. Keyboard Keyswitch Replacement How To, Step 6: Grab New Keyswitch: passo 6, imagem 1 %32
    • Grab your new keyswitch, you don't need the old one anymore. Now first you want to make sure you have the proper amount of pins. For example my keyboard has two and the keyswitch also has 2.
    Pergunte ao FixBot
    Comentar
    • Grab your new keyswitch and line up the pins with the holes in the keyboard. Press firmly and it should pop into place. It may require a bit of force, but you could have also lined up the pins wrong so always double check. It should not wiggle at all, it should be firm and sending signals.
    Pergunte ao FixBot
    Comentar
  5. Keyboard Keyswitch Replacement How To, Step 8: Check Keycap: passo 8, imagem 1 %32
    • The keycap and keyswitch both have the cross hole. They should line up when installing.
    Pergunte ao FixBot
    Comentar
    • The keycap should just pop on and it should fit. Make sure that its facing the right way and in the correct position. Now you are finished! it should click, sound and send signals like all the other ones (considering you are replacing all of them, if not it still should send signals and sound and click like the other new ones.)
    Pergunte ao FixBot
    Comentar
Conclusão
Just rinse and repeat for all the keys you need replaced!
Uma outra pessoa concluiu este guia.
SemiNormalHuman
Membro desde: 04/16/26
169 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 22
Ao todo: 65
