Ir para o conteúdo principal
Keurig K55 Lid Spring Replacement
O que você precisa
  1. Keurig K55 Lid Spring Replacement, Secondary Water Pump: passo 1, imagem 1 %32 Keurig K55 Lid Spring Replacement, Secondary Water Pump: passo 1, imagem 2 %32 Keurig K55 Lid Spring Replacement, Secondary Water Pump: passo 1, imagem 3 %32
    • Lift the silver handle up.
    • Locate the screw and washer holding the handle in place on each side.
    • Remove both 13mm screws and washers using a Phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Keurig K55 Lid Spring Replacement: passo 2, imagem 1 %32 Keurig K55 Lid Spring Replacement: passo 2, imagem 2 %32
    • Grab the handle and pull it upward and toward the rear of the device.
    • Lift the lid to the fully open position.
    • Remove the two 11mm Phillips screws located on the upper part of the device.
    • Be careful removing the screws; the needle here may be sharp.
    Pergunte ao FixBot
    Comentar
  3. Keurig K55 Lid Spring Replacement: passo 3, imagem 1 %32 Keurig K55 Lid Spring Replacement: passo 3, imagem 2 %32 Keurig K55 Lid Spring Replacement: passo 3, imagem 3 %32
    • Lower the lid to just before its closing position.
    • Grab the black top cover with the Keurig logo and gently push back toward the rear of the device to release it.
    • Gently pull the top cover upward and toward the front of the device to remove it.
    Pergunte ao FixBot
    Comentar
  4. Keurig K55 Lid Spring Replacement: passo 4, imagem 1 %32 Keurig K55 Lid Spring Replacement: passo 4, imagem 2 %32 Keurig K55 Lid Spring Replacement: passo 4, imagem 3 %32
    • Remove the two 11mm Phillips head screws securing the water pump.
    • Grab the secondary water pump firmly and pull one of the plastic water lines off of the pump.
    • Pull the other line from the water pump.
    Pergunte ao FixBot
    Comentar
  5. Keurig K55 Lid Spring Replacement, Lid Spring: passo 5, imagem 1 %32 Keurig K55 Lid Spring Replacement, Lid Spring: passo 5, imagem 2 %32
    • Pull the spring off the front hook using two fingers.
    • The spring has a lot of tension, so grip the spring end tightly.
    Pergunte ao FixBot
    Comentar
  6. Keurig K55 Lid Spring Replacement: passo 6, imagem 1 %32 Keurig K55 Lid Spring Replacement: passo 6, imagem 2 %32
    • Pull the spring off the other hook.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team S1-G3, Livingston Winter 2018 Membro de Cal Poly, Team S1-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G3
4 Membros
Autoria de 15 guias
2Comentários do guia
What is the small plastic/rubber angled water line part that the front part of the water pump valve is inserted into ?
Joe K - Responder Compartilhar
Well i might have described it as a water pump in my above message, but from what I've read on here it is a check valve, so what is the rubber/plastic small angled water line part that the front of the check valve is inserted into !
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 58
Ao todo: 2,569
