Ir para o conteúdo principal
Kenmore 80 Series Washing Machine Lid Switch Replacement
O que você precisa
  1. Kenmore 80 Series Washing Machine Lid Switch Replacement, open console: passo 1, imagem 1 %32 Kenmore 80 Series Washing Machine Lid Switch Replacement, open console: passo 1, imagem 2 %32
    • Control panel console is fastened with two screws. Remove screws, pull bottom end of control panel forward (towards you), swing it upward, rest it in flipped position.
  2. Kenmore 80 Series Washing Machine Lid Switch Replacement, unplug switch: passo 2, imagem 1 %32 Kenmore 80 Series Washing Machine Lid Switch Replacement, unplug switch: passo 2, imagem 2 %32
    • Press on tab to release clip/latch. Grip connector, not wires, and pull it off of fixed connector.
  3. Kenmore 80 Series Washing Machine Lid Switch Replacement, open case: passo 3, imagem 1 %32 Kenmore 80 Series Washing Machine Lid Switch Replacement, open case: passo 3, imagem 2 %32 Kenmore 80 Series Washing Machine Lid Switch Replacement, open case: passo 3, imagem 3 %32
    • Use prise tool to remove two case clips. Pull top of case towards you, rock case (almost whole cabinet: case top, front, left & right) on its bottom front edge as axis, lower front of case until it rests on floor.
  4. Kenmore 80 Series Washing Machine Lid Switch Replacement, remove wiring: passo 4, imagem 1 %32 Kenmore 80 Series Washing Machine Lid Switch Replacement, remove wiring: passo 4, imagem 2 %32 Kenmore 80 Series Washing Machine Lid Switch Replacement, remove wiring: passo 4, imagem 3 %32
    • Case grounding wire is fastened on with one screw, 5/16 (five sixteenths) inch hexagon head. Unhook wires from the guide hooks.
  5. Kenmore 80 Series Washing Machine Lid Switch Replacement, remove switch: passo 5, imagem 1 %32 Kenmore 80 Series Washing Machine Lid Switch Replacement, remove switch: passo 5, imagem 2 %32
    • Switch is fastened on with two screws.
    • Remove connector from case top, squeezing connector's panel mount tabs to free it. when replacing: Face connector with its wedge bump facing frontward.
Conclusão
unsubstantiated
Membro desde: 06/07/16
1.066 Reputação
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 55
Últimos 30 dias: 199
Duração total: 9,151
