Ir para o conteúdo principal
Kano Computer Kit Complete Display Board Replacement
O que você precisa
  1. Kano Computer Kit Complete Display Board Replacement, Display Board: passo 1, imagem 1 %32 Kano Computer Kit Complete Display Board Replacement, Display Board: passo 1, imagem 2 %32
    • Take off the clear backing of the computer and set it aside.
    • The Display board is located in the top right corner of the case.
    Pergunte ao FixBot
    Comentar
  2. Kano Computer Kit Complete Display Board Replacement: passo 2, imagem 1 %32 Kano Computer Kit Complete Display Board Replacement: passo 2, imagem 2 %32
    • Always disconnect the battery before performing repairs.
    • Remove the power cable (Circled in red) from the board.
    Pergunte ao FixBot
    Comentar
  3. Kano Computer Kit Complete Display Board Replacement: passo 3, imagem 1 %32 Kano Computer Kit Complete Display Board Replacement: passo 3, imagem 2 %32 Kano Computer Kit Complete Display Board Replacement: passo 3, imagem 3 %32
    • Unplug the HDMI cable (Circled in Yellow) from the board
    Pergunte ao FixBot
    Comentar
  4. Kano Computer Kit Complete Display Board Replacement: passo 4, imagem 1 %32
    • Unscrew the four 8.5mm screws with your Phillips #1 Screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Kano Computer Kit Complete Display Board Replacement: passo 5, imagem 1 %32 Kano Computer Kit Complete Display Board Replacement: passo 5, imagem 2 %32
    • Lift the board off the back of the screen.
    • Be gentle as there is a ribbon cable on the underside that will prevent the board from being removed completely.
    Pergunte ao FixBot
    Comentar
  6. Kano Computer Kit Complete Display Board Replacement: passo 6, imagem 1 %32 Kano Computer Kit Complete Display Board Replacement: passo 6, imagem 2 %32
    • Disconnect the white ribbon cable that you find underneath the board.
    • Be careful; it will take some force.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 2,071
