Ir para o conteúdo principal
KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement
O que você precisa
  1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: passo 1, imagem 1 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: passo 1, imagem 2 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: passo 1, imagem 3 %32
    • Insert the key cap puller into the cracks around the keycap.
    • Twist the tool around the bottom of the keycap.
    • Hold the keyboard down, and pull on the keycap slowly.
    • Pull up as straight as possible.
    • Force required to pull a keycap may vary from soft to heavy.
  2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 2, imagem 1 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 2, imagem 2 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 2, imagem 3 %32
    • Proceed to remove the surrounding keycaps.
  3. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 3, imagem 1 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 3, imagem 2 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 3, imagem 3 %32
    • Flip the keyboard over so that the bottom is facing upward.
    • Slip an opening pick beneath the warranty sticker.
    • Proceed to pull the sticker off to reveal the hole.
  4. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 4, imagem 1 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 4, imagem 2 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 4, imagem 3 %32
    • Use a Phillips #1 Screwdriver to remove the 10 mm screw.
  5. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 5, imagem 1 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 5, imagem 2 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 5, imagem 3 %32
    • Slip an opening tool into the cracks at the indicated points.
    • Pry open carefully.
  6. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 6, imagem 1 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 6, imagem 2 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 6, imagem 3 %32
    • Flip the keyboard so that the keys are facing upward.
    • Grab the sides of the top case and pull up gently.
  7. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 7, imagem 1 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 7, imagem 2 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 7, imagem 3 %32
    • Separate the plate from the bottom case slightly.
    • Reach within and remove the daughterboard cable.
  8. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 8, imagem 1 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 8, imagem 2 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 8, imagem 3 %32
    • Turn the plate over.
    • Locate the pins for the key switch.
    • All the key switches are labeled with their ASCII designation.
  9. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 9, imagem 1 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 9, imagem 2 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada neste passo:
    Desoldering Pump
    $3.99
    • Desolder the pins with a soldering iron and a desoldering pump.
    • Repeat until the pins freely move inside the wells without heat.
    • Placing the soldering iron too close to the PCB may damage it.
  10. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 10, imagem 1 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 10, imagem 2 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 10, imagem 3 %32
    • Wedge two opening tools under the key switch.
    • Pull up gently.
    • If the key switch appears to be immovable, consider repeating step 9.
  11. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 11, imagem 1 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 11, imagem 2 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 11, imagem 3 %32
    • Insert a new key switch into the well with pins corresponding to that of the PCBs.
  12. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 12, imagem 1 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 12, imagem 2 %32 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: passo 12, imagem 3 %32
    • Solder the pins onto the PCB ensuring the solder stays within the wells of the pins.
    • Ensure the pins do not freely move after soldering.
    • Ensure that there is no solder connecting the two pins, as this can possibly cause a short circuit.
Conclusão
To reassemble your device, follow these instructions in reverse order starting at step 7.
Kenny Nguyen
Membro desde: 07/05/20
268 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 34
Ao todo: 1,985
