Ir para o conteúdo principal
K. Preflight Checklist-Motion
  1. K. Preflight Checklist-Motion, Homing X&Y: passo 1, imagem 1 %32 K. Preflight Checklist-Motion, Homing X&Y: passo 1, imagem 2 %32
    • Press Home X. The hot end should move to the left towards the end stop. It will bump the end stop move to the right a few mm, than back left to the end stop and stop.
    • Measure the distance from the edge of the Top X Mount to the edge of the bearing block. Jog the hot end +10mm and re-measure. It should be 10mm larger.
    • Press Home Y. The hot end should move to the back towards the end stop. It will bump the end stop move to forward a few mm, than to the back to the end stop and stop.
    • Measure the distance from the edge of the rear corner to the edge of the bearing block. Jog the hot end -10mm and re-measure. It should be 10mm larger.
    Pergunte ao FixBot
    Comentar
  2. K. Preflight Checklist-Motion, Homing Z: passo 2, imagem 1 %32 K. Preflight Checklist-Motion, Homing Z: passo 2, imagem 2 %32
    • During bed leveling, you want the probe position to be at the center of the bed, not the nozzle. Once you have your X and Y coordinates calculated press Home Z
    • The probe(not the nozzle) will move to the center of the bed, Deploy the probe, raise the bed, stop once the probe is triggered, and lower the bed.
    • If your probe is slightly off center we need to correct it. Manually jog the hotend so the probe is in the center of the bed. Note the coordinates
    • Take the coordinates off the web page and replace them in homez.g and homeall.g
    • G1 X178.75 Y155.2 F10000 ; go to first probe point
    Pergunte ao FixBot
    Comentar
  3. K. Preflight Checklist-Motion, Motion: passo 3, imagem 1 %32
    • Manually jog the hot end
    • When you jog +X it will move to the right
    • When you jog +Y it will move towards the back.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
David Husolo
Membro desde: 06/16/21
9.382 Reputação
Autoria de 33 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 27
Ao todo: 1,385
