Ir para o conteúdo principal
Jeans 2-Hole Button Replacement
O que você precisa
  1. Jeans 2-Hole Button Replacement, 2-Hole Button: passo 1, imagem 1 %32
    • Find a thread color that matches the fabric you are sewing the button on to.
  2. Jeans 2-Hole Button Replacement: passo 2, imagem 1 %32
    • Loop the thread through the eye of the needle.
    • Tie a small knot around the eye of the needle with the thread.
    • Make sure the knot is tight!
  3. Jeans 2-Hole Button Replacement: passo 3, imagem 1 %32
    • Thread the needle through the fabric from the inside out.
    • Tie a knot at the end of the thread after pulling most of it through the fabric.
  4. Jeans 2-Hole Button Replacement: passo 4, imagem 1 %32 Jeans 2-Hole Button Replacement: passo 4, imagem 2 %32 Jeans 2-Hole Button Replacement: passo 4, imagem 3 %32
    • Sew the thread in a small 'x' where you would like to place the button.
    • If you don't want to sew, then mark the spot with a white fabric marker.
  5. Jeans 2-Hole Button Replacement: passo 5, imagem 1 %32 Jeans 2-Hole Button Replacement: passo 5, imagem 2 %32 Jeans 2-Hole Button Replacement: passo 5, imagem 3 %32
    • Place the button over the small stitched 'x' or fabric marker spot.
    • Thread the needle through the left hole of the button from the inside out.
    • Pull the needle and thread all the way through the fabric.
    • If you can't find the hole of the button, thread the needle through the fabric first and then through the button hole.
  6. Jeans 2-Hole Button Replacement: passo 6, imagem 1 %32 Jeans 2-Hole Button Replacement: passo 6, imagem 2 %32 Jeans 2-Hole Button Replacement: passo 6, imagem 3 %32
    • Cross the needle over to the right hole of the button.
    • Thread the needle all the way through the fabric.
    • This step creates the first stitch.
  7. Jeans 2-Hole Button Replacement: passo 7, imagem 1 %32
    • Repeat Steps 6-7 four to five times, until you have a secure button.
  8. Jeans 2-Hole Button Replacement: passo 8, imagem 1 %32
    • Create a thread shank on the inside of the fabric by looping the thread around a stitch.
    • Pull the thread all the way through the hole until it is tight.
    • Repeat this 2-3 times.
    • Tie a knot after the final stitch to secure the stitches.
  9. Jeans 2-Hole Button Replacement: passo 9, imagem 1 %32 Jeans 2-Hole Button Replacement: passo 9, imagem 2 %32
    • Use fabric scissors to cut off excess thread.
Conclusão
After cutting the remaining thread, your button stays on your jeans.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 82
Ao todo: 2,291
