Introdução
This guide will walk you through the process of replacing the motherboard, to get your tablet working again. This replacement requires soldering skills. Learn more about soldering, here.
O que você precisa
Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
Remove the two pieces of tape securing the ribbon cables to the motherboard.
