Ir para o conteúdo principal
Jazz UltraTab C855 Battery Replacement
O que você precisa
    1. Jazz UltraTab C855 Battery Replacement, Back Cover: passo 1, imagem 1 %32
      Pergunte ao FixBot
      Comentar
    2. Jazz UltraTab C855 Battery Replacement: passo 2, imagem 1 %32
      • Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
      Pergunte ao FixBot
      Comentar
    1. Jazz UltraTab C855 Battery Replacement, Battery: passo 3, imagem 1 %32
      • Remove the yellow tape from the sides of the battery, and the surrounding components.
      Pergunte ao FixBot
      Comentar
    2. Jazz UltraTab C855 Battery Replacement: passo 4, imagem 1 %32
      • Cut the pos(+) and neg (-) wires that connect the battery to the device using wire cutters.
      • Cut the wires towards the middle. During installation of your new battery these wires will be stripped back and soldered or crimped to reattach.
      Pergunte ao FixBot
      Comentar
    3. Jazz UltraTab C855 Battery Replacement: passo 5, imagem 1 %32
      • Using a plastic opening tool or spudger, slowly pry the battery away from the board.
      • The battery is secured to the device with adhesive.
      • Metal spudgers can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      Pergunte ao FixBot
      Comentar
    4. Jazz UltraTab C855 Battery Replacement: passo 6, imagem 1 %32
      • Use a two sided adhesive to secure the new battery in place.
      • Solder or crimp the wires back together to reattach to the motherboard.
      • Replace any yellow tape that you removed at the beginning to secure the wires back in place.
      Pergunte ao FixBot
      Comentar
Conclusão
Cory Hodge
Membro desde: 09/14/15
201 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 1-3, Baechle Fall 2015 Membro de IUPUI, Team 1-3, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G3
5 Membros
Autoria de 10 guias
1Comentário do guia
Very good instructions.....but where do I buy the repkacement battery from?
fremontmyers - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 793
