Ir para o conteúdo principal
Jazz Digi-Stix JDC11 Lens Replacement
O que você precisa
    1. Jazz Digi-Stix JDC11 Lens Replacement, Battery: passo 1, imagem 1 %32 Jazz Digi-Stix JDC11 Lens Replacement, Battery: passo 1, imagem 2 %32
      • Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
      Pergunte ao FixBot
      Comentar
    2. Jazz Digi-Stix JDC11 Lens Replacement: passo 2, imagem 1 %32
      • Tilt device so that batteries slide out.
      Pergunte ao FixBot
      Comentar
    1. Jazz Digi-Stix JDC11 Lens Replacement, Lens: passo 3, imagem 1 %32 Jazz Digi-Stix JDC11 Lens Replacement, Lens: passo 3, imagem 2 %32 Jazz Digi-Stix JDC11 Lens Replacement, Lens: passo 3, imagem 3 %32
      • Carefully insert the flat end of the spudger into the seam on the top side of the device. Carefully twist the spudger to open the device. Repeat this step at incremental locations around the seam of the device until the two case halves separate.
      • Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart. Take care not to break the plastic hinge as the battery compartment cover is removed.
      Pergunte ao FixBot
      Comentar
    2. Jazz Digi-Stix JDC11 Lens Replacement: passo 4, imagem 1 %32 Jazz Digi-Stix JDC11 Lens Replacement: passo 4, imagem 2 %32 Jazz Digi-Stix JDC11 Lens Replacement: passo 4, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Make sure to take care in prying case apart. There are two wires (one red and one black) that could get disconnected from the motherboard.
      • Gently seperate the two halves of the device.
      • To remove the circuit board from the right section of the device, unscrew the two 5.6 mm Phillips #00 screws.
      • When the screws have been fully unscrewed, use the tweezers to remove them from the device.
      Pergunte ao FixBot
      Comentar
    3. Jazz Digi-Stix JDC11 Lens Replacement: passo 5, imagem 1 %32 Jazz Digi-Stix JDC11 Lens Replacement: passo 5, imagem 2 %32 Jazz Digi-Stix JDC11 Lens Replacement: passo 5, imagem 3 %32
      • Turn the device over so that the lens is facing downward. Take care not to detach any wires during this step.
      • Locate and unscrew the two 5.6 mm Phillips #00 screws holding the lens to the board.
      • Turn the device back over so that the lens faces upward, and carefully remove the lens from the board.
      Pergunte ao FixBot
      Comentar
Conclusão
Katelyn Fry
Membro desde: 03/11/13
1 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 12-3, Benson Spring 2013 Membro de Clemson, Team 12-3, Benson Spring 2013
CLEM-BENSON-S13S12G3
3 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 18
Ao todo: 554
