Ir para o conteúdo principal
Jam Voice Speaker Replacement
O que você precisa
  1. Jam Voice Speaker Replacement, Hard Mesh Cover: passo 1, imagem 1 %32 Jam Voice Speaker Replacement, Hard Mesh Cover: passo 1, imagem 2 %32
    • Insert the plastic opening tool underneath the mesh top.
    • Pry the cover open.
    • To reattach the cover, simply align the round posts on the bottom of the cover into the holes.
    Pergunte ao FixBot
    Comentar
  2. Jam Voice Speaker Replacement, Motherboard: passo 2, imagem 1 %32
    • Remove the four 7mm Phillips screws from the plastic cover.
    Pergunte ao FixBot
    Comentar
  3. Jam Voice Speaker Replacement: passo 3, imagem 1 %32 Jam Voice Speaker Replacement: passo 3, imagem 2 %32
    • Remove the four 5mm Phillips screws that hold down the speaker in place.
    • Remove the two 6mm Phillips screws that hold down the plastic casing.
    Pergunte ao FixBot
    Comentar
  4. Jam Voice Speaker Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    Halberd Spudger
    $2.99
    • Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
    • Pull the speaker up and out.
    Pergunte ao FixBot
    Comentar
  5. Jam Voice Speaker Replacement: passo 5, imagem 1 %32 Jam Voice Speaker Replacement: passo 5, imagem 2 %32 Jam Voice Speaker Replacement: passo 5, imagem 3 %32
    • Remove the four 7mm Phillips screws to expose the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Jam Voice Speaker Replacement: passo 6, imagem 1 %32
    • After removing all of the screws from the plastic cover, remove it by pulling up and out.
    • Be careful not to pull and damage any of the wires.
    Pergunte ao FixBot
    Comentar
  7. Jam Voice Speaker Replacement: passo 7, imagem 1 %32 Jam Voice Speaker Replacement: passo 7, imagem 2 %32
    • Remove the three 5mm Phillips screws that hold the motherboard in place.
    • After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
    Pergunte ao FixBot
    Comentar
  8. Jam Voice Speaker Replacement, Speaker: passo 8, imagem 1 %32
    • Use tweezers to pull out the speaker's wire from the motherboard.
    • Use tweezers to pull out the battery's wire from the motherboard.
    • The speaker's connection point is opposite the battery's connection point.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 30
Ao todo: 918
