Ir para o conteúdo principal
Introdução
If the speaker is distorted or not functioning, you may need to replace it. This guide will give you step-by-step instructions on how to replace the speaker in the Jabra Speak 510.
  1. Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws. Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Remove the six 20 mm T6 screws from the bottom of the device.
    • Remove the six 20 mm T6 screws from the bottom of the device.
  3. Remove the back plate and the grey foam underneath. Remove the back plate and the grey foam underneath.
    • Remove the back plate and the grey foam underneath.
  4. Use a small, pointed metal spudger to  release the plastic tabs connecting the faceplate to the bottom of the speaker. A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening  the device. Slowly flip the device open like a clam shell.
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
  5. Desolder the two wires running to the speaker. You can find soldering tips in the How To Solder and Desolder Connections guide.
Conclusão
2 outras pessoas concluíram este guia.
Jordan Murphy
Membro desde: 16-02-2016
510 Reputation
3 Guias de autoria
IUPUI, Team 2-3, Harley Spring 2016 Membro de IUPUI, Team 2-3, Harley Spring 2016
IUPUI-HARLEY-S16S2G3
4 Membros
4 Guias de autoria
soleniall buen aporteee
bryanpinedaza - Responder
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 42
All Time: 1,886
