Ir para o conteúdo principal
Jabra Speak 510 Motherboard Replacement
O que você precisa
  1. Jabra Speak 510 Motherboard Replacement, Outer Casing: passo 1, imagem 1 %32 Jabra Speak 510 Motherboard Replacement, Outer Casing: passo 1, imagem 2 %32
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Jabra Speak 510 Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the six 20 mm T6 screws from the bottom of the device.
  3. Jabra Speak 510 Motherboard Replacement: passo 3, imagem 1 %32 Jabra Speak 510 Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the back plate and the grey foam underneath.
  4. Jabra Speak 510 Motherboard Replacement: passo 4, imagem 1 %32 Jabra Speak 510 Motherboard Replacement: passo 4, imagem 2 %32 Jabra Speak 510 Motherboard Replacement: passo 4, imagem 3 %32
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
  5. Jabra Speak 510 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Jabra Speak 510 Motherboard Replacement, Motherboard: passo 5, imagem 2 %32
    • Using the T6 Torx Screwdriver, remove the four (4mm) screws.
  6. Jabra Speak 510 Motherboard Replacement: passo 6, imagem 1 %32
    • After removing the screws, take out the center covering to free the motherboard by lifting the tabs and pulling it off.
  7. Jabra Speak 510 Motherboard Replacement: passo 7, imagem 1 %32 Jabra Speak 510 Motherboard Replacement: passo 7, imagem 2 %32
    • Peel off the white adhesive to desolder the connections underneath.
    • Desolder the wires connected to the motherboard.
    • You can find soldering tips in the How To Solder and Desolder Connections guide.
    • Keep track of where the wires are connected. When re-assembling you will have to connect the wires in the correct spot.
Conclusão
4 outras pessoas executaram este guia.
Jordan Murphy
Membro desde: 02/16/16
717 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 2-3, Harley Spring 2016 Membro de IUPUI, Team 2-3, Harley Spring 2016
IUPUI-HARLEY-S16S2G3
Membros da 4
Autoria de 8 guias
3 comentários
Great walk-through... thanks
Walaa Maher - Responder
Be very careful when desoldering the connector cables! The soldering lugs are poor quality and tend to tear off the PCB
Thomas Sprenger - Responder
Hello
Where I can buy the motherboard replacement?
Regards
Lobo Gris - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 24
Últimos 30 dias: 81
Duração total: 7,444
