Ir para o conteúdo principal
Jabra Evolve2 65 Battery Replacement
O que você precisa
  1. Jabra Evolve2 65 Battery Replacement, Ear Pads: passo 1, imagem 1 %32
    • Lay your headphones down on a flat, solid surface.
    Pergunte ao FixBot
    Comentar
  2. Jabra Evolve2 65 Battery Replacement: passo 2, imagem 1 %32 Jabra Evolve2 65 Battery Replacement: passo 2, imagem 2 %32
    • Insert an opening tool into the seam between the ear pad and driver housing, near the hinge.
    • Gently pry the ear pad away from the driver housing until it releases.
    Pergunte ao FixBot
    Comentar
  3. Jabra Evolve2 65 Battery Replacement: passo 3, imagem 1 %32 Jabra Evolve2 65 Battery Replacement: passo 3, imagem 2 %32
    • Pry off the other ear pad in the same manner.
    Pergunte ao FixBot
    Comentar
  4. Jabra Evolve2 65 Battery Replacement, Motherboard: passo 4, imagem 1 %32 Jabra Evolve2 65 Battery Replacement, Motherboard: passo 4, imagem 2 %32
    • Peel back the tape where the microphone's base connects to the headband.
    • Use a T6 Torx screwdriver to remove the single 2 mm screw.
    Pergunte ao FixBot
    Comentar
  5. Jabra Evolve2 65 Battery Replacement: passo 5, imagem 1 %32
    • Go about a third of the way around the first screw and peel back the tape to locate the second screw.
    • Use T6 Torx screwdriver to remove the single 2 mm screw.
    Pergunte ao FixBot
    Comentar
  6. Jabra Evolve2 65 Battery Replacement: passo 6, imagem 1 %32
    • Locate the third screw after peeling the tape off entirely after removing the second screw.
    • Use a T6 Torx screwdriver to remove the final 2 mm screw.
    Pergunte ao FixBot
    Comentar
  7. Jabra Evolve2 65 Battery Replacement: passo 7, imagem 1 %32 Jabra Evolve2 65 Battery Replacement: passo 7, imagem 2 %32 Jabra Evolve2 65 Battery Replacement: passo 7, imagem 3 %32
    • Use an opening tool to pry up and set aside the driver housing.
    • Gently remove the motherboard from the housing..
    Pergunte ao FixBot
    Comentar
  8. Jabra Evolve2 65 Battery Replacement: passo 8, imagem 1 %32 Jabra Evolve2 65 Battery Replacement: passo 8, imagem 2 %32 Jabra Evolve2 65 Battery Replacement: passo 8, imagem 3 %32
    • After locating the battery underneath, use a pair of tweezers to disconnect all connected cables.
    • Using tweezers, gently wiggle out the connector that joins the battery to the motherboard. The correct connector will be labeled on the motherboard and is the one that contains 2 wires, one black and one red.
    Pergunte ao FixBot
    Comentar
  9. Jabra Evolve2 65 Battery Replacement: passo 9, imagem 1 %32
    • Using a soldering iron, desolder the driver connections from the motherboard.
    • When reinstalling the driver to the motherboard, make sure you solder the driver connections to the correct terminals. The red wire goes to the "P" and the black wire goes to the "N."
    Pergunte ao FixBot
    Comentar
  10. Jabra Evolve2 65 Battery Replacement, Battery: passo 10, imagem 1 %32 Jabra Evolve2 65 Battery Replacement, Battery: passo 10, imagem 2 %32 Jabra Evolve2 65 Battery Replacement, Battery: passo 10, imagem 3 %32
    • Using an opening tool, gently pry out the battery.
    Pergunte ao FixBot
    Comentar
Conclusão
JPittsley
Membro desde: 03/21/25
218 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 3-2, Botvin Spring 2025 Membro de UMass Dartmouth, Team 3-2, Botvin Spring 2025
UMASSD-BOTVIN-S25S3G2
4 Membros
Autoria de 15 guias
1Comentário do guia
How do I get the battery replacement
KAMUGISHA ALLAN - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 68
Últimos 30 dias: 326
Ao todo: 2,354
