Ir para o conteúdo principal
Jabra Elite 85h Bluetooth Module Replacement
O que você precisa
  1. Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: passo 1, imagem 1 %32 Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: passo 1, imagem 2 %32 Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: passo 1, imagem 3 %32
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
    Pergunte ao FixBot
    Comentar
  2. Jabra Elite 85h Bluetooth Module Replacement: passo 2, imagem 1 %32 Jabra Elite 85h Bluetooth Module Replacement: passo 2, imagem 2 %32 Jabra Elite 85h Bluetooth Module Replacement: passo 2, imagem 3 %32
    • The foam inserts and backing tape are very delicate, take your time when removing them and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
    Pergunte ao FixBot
    Comentar
  3. Jabra Elite 85h Bluetooth Module Replacement: passo 3, imagem 1 %32 Jabra Elite 85h Bluetooth Module Replacement: passo 3, imagem 2 %32 Jabra Elite 85h Bluetooth Module Replacement: passo 3, imagem 3 %32
    • Repeat previous steps on other side.
    Pergunte ao FixBot
    Comentar
  4. Jabra Elite 85h Bluetooth Module Replacement: passo 4, imagem 1 %32
    • Unscrew and remove the four T6 screws holding the speaker in place.
    Pergunte ao FixBot
    Comentar
  5. Jabra Elite 85h Bluetooth Module Replacement: passo 5, imagem 1 %32
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
    Pergunte ao FixBot
    Comentar
  6. Jabra Elite 85h Bluetooth Module Replacement: passo 6, imagem 1 %32 Jabra Elite 85h Bluetooth Module Replacement: passo 6, imagem 2 %32
    • Remove the two screws holding the upper and lower circuit boards in place.
    Pergunte ao FixBot
    Comentar
  7. Jabra Elite 85h Bluetooth Module Replacement: passo 7, imagem 1 %32 Jabra Elite 85h Bluetooth Module Replacement: passo 7, imagem 2 %32
    • Remove the two attached circuit boards from the headphone housing.
    • De-solder Bluetooth Module from control board to replace.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Ryan Callaghan
Membro desde: 03/13/23
965 Reputação
Autoria de 4 guias
Equipe
2Comentários do guia
But where could one get this Bluetooth Module? Is it only available for Jabra workers?
sarita sulkakoski - Responder Compartilhar
Anyone can tell how I can get parts for this thing - need main module
Janusz Pokorski (Smartthing) - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 43
Ao todo: 2,548
