Ir para o conteúdo principal
Jabra CRUISER2 Speaker Replacement
O que você precisa
  1. Jabra CRUISER2 Speaker Replacement, Front Plate: passo 1, imagem 1 %32
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • iOpener Instructions
  2. Jabra CRUISER2 Speaker Replacement: passo 2, imagem 1 %32
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Jabra CRUISER2 Speaker Replacement: passo 3, imagem 1 %32
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Speaker Replacement, Speaker: passo 4, imagem 1 %32 Jabra CRUISER2 Speaker Replacement, Speaker: passo 4, imagem 2 %32
    • Carefully unplug the red and black wires that run from the speaker to the motherboard by detaching the white connecting piece.
  5. Jabra CRUISER2 Speaker Replacement: passo 5, imagem 1 %32
    • Using the PH000, unscrew the two 5.5mm screws attaching the speaker to the front plate.
    • The screwdriver sizes are located on the sides of their heads.
  6. Jabra CRUISER2 Speaker Replacement: passo 6, imagem 1 %32
    • Gently pull the black and red wires away from the back plate to remove the speaker.
  7. Jabra CRUISER2 Speaker Replacement: passo 7, imagem 1 %32 Jabra CRUISER2 Speaker Replacement: passo 7, imagem 2 %32
    • Carefully pull the wires away from the speaker, detaching them from the adhesive, while keeping the ends intact.
Conclusão
Spartacus
Membro desde: 10/17/14
636 Reputação
Autoria de 5 guias
Equipe
Baylor, Team 8-13, Williams Fall 2014 Membro de Baylor, Team 8-13, Williams Fall 2014
BU-WILLIAMS-F14S8G13
Membros da 3
Autoria de 5 guias
5 comentários
Is this a fairly standard speaker? With radio shack dead, can you suggest a source? Any specs? Yhanks
Brucereno2 - Responder
Did you ever find a speaker for your jabra cruiser?
Scot Tetreault -
halo
where i can get the new speaker for jabra cruiser 2?
Frantisek Fridrich - Responder
simple speaker in electronic parts shop 8ohm diameter 35mm price 1.2 €
A 36 mm speaker will also fit nicely. A 1 watt 8 ohms speaker is the best choice - the amplifier is not able to output enough power to drive a 2+ watt speaker.
Mobi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 9
Duração total: 1,860
