Ir para o conteúdo principal
Jabra CRUISER2 Motherboard Replacement
O que você precisa
  1. Jabra CRUISER2 Motherboard Replacement, Front Plate: passo 1, imagem 1 %32
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • iOpener Instructions
  2. Jabra CRUISER2 Motherboard Replacement: passo 2, imagem 1 %32
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Jabra CRUISER2 Motherboard Replacement: passo 3, imagem 1 %32
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 Jabra CRUISER2 Motherboard Replacement, Motherboard: passo 4, imagem 2 %32
    • Carefully detach the wire running from the speaker to the motherboard by unplugging it from the white socket.
  5. Jabra CRUISER2 Motherboard Replacement: passo 5, imagem 1 %32
    • Using the PH000, unscrew the three 4.55 mm screws in the motherboard.
    • The names of the screwdriver heads are listed on the sides of each head.
  6. Jabra CRUISER2 Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the motherboard from the device by lifting it up from the back plate.
Conclusão
Spartacus
Membro desde: 10/17/14
636 Reputação
Autoria de 5 guias
Equipe
Baylor, Team 8-13, Williams Fall 2014 Membro de Baylor, Team 8-13, Williams Fall 2014
BU-WILLIAMS-F14S8G13
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 789
