Introdução
The shocks are located slightly above the front wheel of the JD Razor 2000 and assist the rider in braking and reduces stress on the load-bearing points of the scooter.
O que você precisa
Orient the scooter so that the front wheel is facing you. Observe the right and left side of the wheel. Remember which is which throughout the guide.
Using an Allen wrench, unscrew the axle bolt slowly from the right side while applying a constant pressure with your hand on the left side of the bearing.
Carefully pull apart the bolt and bearing from either side of the wheel.
Find the axle bolt behind the shocks. It should look similar to the one used to remove the front wheel.
Remove the bolt in the same manner as the wheel. While applying pressure to the left side, unscrew the right using an Allen wrench.
Remove the bolt and bearing and the black rubber stoppers. Remove the metal tube between the bolt.
Firmly grasp the metal piece that holds the wheel and gently pull it away.
1Comentário do guia
I’ve been looking and can’t find the part that would fit here. Does anyone have any suggestions for compatible parts? The link at the top doesn’t work.
