Ir para o conteúdo principal
JBL Tune 510BT Headphone Speaker Driver Replacement
O que você precisa
  1. JBL Tune 510BT Headphone Speaker Driver Replacement, Faceplate: passo 1, imagem 1 %32 JBL Tune 510BT Headphone Speaker Driver Replacement, Faceplate: passo 1, imagem 2 %32
    • Firmly grasp the earmuff and pull away from the center until the lip of the earmuff is disengaged.
    • Pull the earmuff towards the center of the headphones until it is free.
  2. JBL Tune 510BT Headphone Speaker Driver Replacement: passo 2, imagem 1 %32 JBL Tune 510BT Headphone Speaker Driver Replacement: passo 2, imagem 2 %32
    • Remove the three 3 mm screws using a JIS #00 screwdriver.
  3. JBL Tune 510BT Headphone Speaker Driver Replacement: passo 3, imagem 1 %32
    • Carefully remove the faceplate by lifting it firmly.
    • Avoid rough movements, as there is a single thin wire connecting the faceplate to the internals.
    • If the repair is for the right-side driver, be mindful of the charging port, as the faceplate has a slot there for it. Lift the opposite end and back the port out.
    • To completely detach the faceplate, desolder the wires from the connections on the motherboard.
  4. JBL Tune 510BT Headphone Speaker Driver Replacement, Headphone Speaker Driver: passo 4, imagem 1 %32 JBL Tune 510BT Headphone Speaker Driver Replacement, Headphone Speaker Driver: passo 4, imagem 2 %32 JBL Tune 510BT Headphone Speaker Driver Replacement, Headphone Speaker Driver: passo 4, imagem 3 %32
    • Pull each of the three pull tabs away from the center of the faceplate, disengaging them and exposing the back of the speaker driver.
    • Push a Jimmy or other pry tool gently between the driver and the grey spacer.
    • Lift gently until the driver is loose, being mindful not to damage the wires connecting to the driver.
  5. JBL Tune 510BT Headphone Speaker Driver Replacement: passo 5, imagem 1 %32 JBL Tune 510BT Headphone Speaker Driver Replacement: passo 5, imagem 2 %32
    • Desolder the two wires from the driver carefully.
    • Orient your new driver and solder the wires to it, making sure to solder the wires to the correct terminals and confirming that the wires aren't crossed.
Conclusão
Ryan
Membro desde: 01/30/24
513 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 19
Últimos 30 dias: 46
Duração total: 71
