Ir para o conteúdo principal
JBL Pulse Outer Casing Replacement
O que você precisa
  1. JBL Pulse Outer Casing Replacement, Button Board: passo 1, imagem 1 %32
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
    Pergunte ao FixBot
    Comentar
  2. JBL Pulse Outer Casing Replacement: passo 2, imagem 1 %32
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
    Pergunte ao FixBot
    Comentar
  3. JBL Pulse Outer Casing Replacement: passo 3, imagem 1 %32
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
    Pergunte ao FixBot
    Comentar
  4. JBL Pulse Outer Casing Replacement: passo 4, imagem 1 %32
    • Lift the button board, exposing the attached cable.
    Pergunte ao FixBot
    Comentar
  5. JBL Pulse Outer Casing Replacement: passo 5, imagem 1 %32
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
    Pergunte ao FixBot
    Comentar
  6. JBL Pulse Outer Casing Replacement, Outer Casing: passo 6, imagem 1 %32 JBL Pulse Outer Casing Replacement, Outer Casing: passo 6, imagem 2 %32 JBL Pulse Outer Casing Replacement, Outer Casing: passo 6, imagem 3 %32
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 18-6, Blackwell Fall 2016 Membro de USF Tampa, Team 18-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G6
3 Membros
Autoria de 13 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 2,902
