Ir para o conteúdo principal
JBL Pulse Motherboard Replacement
O que você precisa
  1. JBL Pulse Motherboard Replacement, Button Board: passo 1, imagem 1 %32
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
    Pergunte ao FixBot
    Comentar
  2. JBL Pulse Motherboard Replacement: passo 2, imagem 1 %32
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
    Pergunte ao FixBot
    Comentar
  3. JBL Pulse Motherboard Replacement: passo 3, imagem 1 %32
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
    Pergunte ao FixBot
    Comentar
  4. JBL Pulse Motherboard Replacement: passo 4, imagem 1 %32
    • Lift the button board, exposing the attached cable.
    Pergunte ao FixBot
    Comentar
  5. JBL Pulse Motherboard Replacement: passo 5, imagem 1 %32
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
    Pergunte ao FixBot
    Comentar
  6. JBL Pulse Motherboard Replacement, Outer Casing: passo 6, imagem 1 %32 JBL Pulse Motherboard Replacement, Outer Casing: passo 6, imagem 2 %32 JBL Pulse Motherboard Replacement, Outer Casing: passo 6, imagem 3 %32
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
    Pergunte ao FixBot
    Comentar
  7. JBL Pulse Motherboard Replacement, JBL Pulse LED Lights Disassembly: passo 7, imagem 1 %32 JBL Pulse Motherboard Replacement, JBL Pulse LED Lights Disassembly: passo 7, imagem 2 %32
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
    Pergunte ao FixBot
    Comentar
  8. JBL Pulse Motherboard Replacement, JBL Pulse Disassembly: passo 8, imagem 1 %32
    • Remove two black 9mm PH0 screws from outside of inner casing on each side.
    Pergunte ao FixBot
    Comentar
  9. JBL Pulse Motherboard Replacement: passo 9, imagem 1 %32 JBL Pulse Motherboard Replacement: passo 9, imagem 2 %32 JBL Pulse Motherboard Replacement: passo 9, imagem 3 %32
    • Use your metal spudger to unhook the bracket holding the case together.
    • Pull apart the casing with your hands.
    Pergunte ao FixBot
    Comentar
  10. JBL Pulse Motherboard Replacement: passo 10, imagem 1 %32 JBL Pulse Motherboard Replacement: passo 10, imagem 2 %32
    • Remove cables by pulling firmly.
    Pergunte ao FixBot
    Comentar
  11. JBL Pulse Motherboard Replacement, Motherboard: passo 11, imagem 1 %32
    • Once all of the cables are removed, grip the motherboard and slide it out.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 18-6, Blackwell Fall 2016 Membro de USF Tampa, Team 18-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G6
3 Membros
Autoria de 13 guias
3Comentários do guia
Excelente, funcionó perfectamente la guia. Compré la bateria y el armado funcionó perfecto. Muchas gracias.
Angel Pérez - Responder Compartilhar
my usb port is damaged. Do I have to replace the whole motherboarD?
dinosdabi - Responder Compartilhar
Hey I need JBL pulse motherboard Where can I buy. Please help
kashyapvikas228vk1070301 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 60
Ao todo: 10,175
