Ir para o conteúdo principal
JBL Pulse 3 Charging Port Replacement
O que você precisa
  1. JBL Pulse 3 Charging Port Replacement, Speaker Grill: passo 1, imagem 1 %32
    • Lay the JBL Pulse 3 on its side as shown in the picture.
    • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
  2. JBL Pulse 3 Charging Port Replacement: passo 2, imagem 1 %32
    • Repeat step 1 for bottom right corner of speaker grill.
  3. JBL Pulse 3 Charging Port Replacement: passo 3, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 3, imagem 2 %32
    • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
    • Lift and pull straight out to pull grill off the posts.
    • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
  4. JBL Pulse 3 Charging Port Replacement, Outside Casing: passo 5, imagem 1 %32 JBL Pulse 3 Charging Port Replacement, Outside Casing: passo 5, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
    #00 not required, successfully opened with PH#1
    Stephen Hoefler - Responder
  5. JBL Pulse 3 Charging Port Replacement: passo 6, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 6, imagem 2 %32
    • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
    Ca I Specifically buy the top ring
    Julian Cruz - Responder
    I've the same concern as the comment above, can I buy the top ring separately?
    Yousef - Responder
    Opening is not as simple as demonstrated in Step 6. I have followed everything through, am I missing something?
    Kusala Kumsinda - Responder
    Is there any other place to get this part? It doesnt ship to the UK
    Amelia - Responder
  6. JBL Pulse 3 Charging Port Replacement: passo 7, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 7, imagem 2 %32
    • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
  7. JBL Pulse 3 Charging Port Replacement: passo 8, imagem 1 %32
    • Pull off the top disc of the JBL Pulse 3.
  8. JBL Pulse 3 Charging Port Replacement: passo 9, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 9, imagem 2 %32
    • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
    This phase could be difficult. Try to “twist” the speaker to have a little gap between both parts and insert gently a screwdriver or opening toile to spread the gap.
    Richard Devos - Responder
  9. JBL Pulse 3 Charging Port Replacement: passo 10, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 10, imagem 2 %32
    • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
  10. JBL Pulse 3 Charging Port Replacement: passo 11, imagem 1 %32
    • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
  11. JBL Pulse 3 Charging Port Replacement, LED Light Display: passo 12, imagem 1 %32 JBL Pulse 3 Charging Port Replacement, LED Light Display: passo 12, imagem 2 %32 JBL Pulse 3 Charging Port Replacement, LED Light Display: passo 12, imagem 3 %32
    • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
    • Pull the LED light display off of the JBL Pulse 3 base.
  12. JBL Pulse 3 Charging Port Replacement: passo 13, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 13, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to pull the five connections off of the LED light display.
    up to step 13, the battery replacement steps are the same.
    From step 14 the steps change.
    Very good instructions for changing the battery in the jbl pulse 3 can be found here:
    https://www.youtube.com/watch?v=MpznDgxg...
    Mike Miker - Responder
  13. JBL Pulse 3 Charging Port Replacement, Motherboard: passo 14, imagem 1 %32 JBL Pulse 3 Charging Port Replacement, Motherboard: passo 14, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the two black 8mm screws on the bottom of the LED light display.
  14. JBL Pulse 3 Charging Port Replacement: passo 15, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 15, imagem 2 %32 JBL Pulse 3 Charging Port Replacement: passo 15, imagem 3 %32
    • Pull out the motherboard slightly from the LED light display as shown. Using tweezers, unplug the three connections attached to the motherboard.
  15. JBL Pulse 3 Charging Port Replacement: passo 16, imagem 1 %32
    • Pull the rest of the motherboard out from the LED light display.
    • Using wire cutters, snip the black wire connecting to the base of the JBL Pulse 3 at the base of the motherboard. The motherboard should now be removed from the JBL Pulse 3.
    Hi Guys! Thanks a lot for the tutorial, but anyone knows where THIS BLACK WIRE IS CONNECTED at the base of the speaker? I accidentally remove it..
    caiopeluso - Responder
  16. JBL Pulse 3 Charging Port Replacement, Speaker: passo 17, imagem 1 %32 JBL Pulse 3 Charging Port Replacement, Speaker: passo 17, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove the four 10mm screws on the corner of the speaker on the side of the base of the JBL Pulse 3.
  17. JBL Pulse 3 Charging Port Replacement: passo 18, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 18, imagem 2 %32
    • Pull out the speaker and cut the black and red wire with wire cutters. The speaker should now be removed from the JBL Pulse 3.
  18. JBL Pulse 3 Charging Port Replacement, Charging Port: passo 19, imagem 1 %32 JBL Pulse 3 Charging Port Replacement, Charging Port: passo 19, imagem 2 %32
    • Repeat the steps to take out all three speakers on the base of the JBL Pulse 3.
    • Using a Phillips #0 screwdriver, remove the 6 mm screw under each of the three speakers around the base of the JBL Pulse 3.
  19. JBL Pulse 3 Charging Port Replacement: passo 20, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 20, imagem 2 %32
    • Grab the outside of the JBL Pulse 3 at the bottom and pull outward until the outside button cover comes off.
  20. JBL Pulse 3 Charging Port Replacement: passo 21, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 21, imagem 2 %32
    • Disconnect the two connections from the inside side of the base of the JBL Pulse 3 by pushing on the wire with your index finger in the opposite direction of the connection.
    My connectors were glued, I had to also remove the bottom plate. Use the tweezers to pull glue off.
    Adam Friesen - Responder
  21. JBL Pulse 3 Charging Port Replacement: passo 22, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 22, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the four 10mm screws by the push buttons on the side of the base of the JBL Pulse 3.
    i want jbl pulse 3 charging port
    sudheer krish - Responder
  22. JBL Pulse 3 Charging Port Replacement: passo 23, imagem 1 %32
    • Pull off the inside button cover with the attached charging port. The charging port should now be removed.
Conclusão
6 outras pessoas executaram este guia.
5Comentários do guia
And how to put it back with cut cable?
Robert Rpunkt - Responder
I've done a teardown and was able to access the charging terminal without cutting any wires. I didn't have a replacement, so I just put it back together hoping that cleaning it would work. Didn't work.
Beresford Crowder - Responder
Yeah its obvious they need to use a C type port they aren't as easy to tear up
Lloyd Mars -
You do not have to tear it completely down unless I have a newer version after you take the speaker grill out from around the unit the thin black skeleton like gram that stiffened the grill will actually unclip from the unit with a hook tool or a ice pick that's been heated up and put a slight bend in it take your time because you can break the frame but even if you do its what they make jb weld and gorilla glue for I broke mine but went back together fine after letting the glue set up sprinkled some baking soda on it and made it twice as strong you've only got 4 screws this way cause they well the replacement plug for around $12 don't know why they don't go ahead and use the C type port smh when these came out they was already selling the replacement plug lol
Lloyd Mars - Responder
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 29
Últimos 30 dias: 122
Ao todo: 17,240
