Ir para o conteúdo principal
JBL Pulse 3 Charging Port Replacement
O que você precisa
  1. JBL Pulse 3 Charging Port Replacement, Speaker Grill: passo 1, imagem 1 %32
    • Lay the JBL Pulse 3 on its side as shown in the picture.
    • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
  2. JBL Pulse 3 Charging Port Replacement: passo 2, imagem 1 %32
    • Repeat step 1 for bottom right corner of speaker grill.
  3. JBL Pulse 3 Charging Port Replacement: passo 3, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 3, imagem 2 %32
    • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
    • Lift and pull straight out to pull grill off the posts.
    • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
  4. JBL Pulse 3 Charging Port Replacement, Outside Casing: passo 5, imagem 1 %32 JBL Pulse 3 Charging Port Replacement, Outside Casing: passo 5, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
  5. JBL Pulse 3 Charging Port Replacement: passo 6, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 6, imagem 2 %32
    • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
  6. JBL Pulse 3 Charging Port Replacement: passo 7, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 7, imagem 2 %32
    • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
  7. JBL Pulse 3 Charging Port Replacement: passo 8, imagem 1 %32
    • Pull off the top disc of the JBL Pulse 3.
  8. JBL Pulse 3 Charging Port Replacement: passo 9, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 9, imagem 2 %32
    • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
  9. JBL Pulse 3 Charging Port Replacement: passo 10, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 10, imagem 2 %32
    • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
  10. JBL Pulse 3 Charging Port Replacement: passo 11, imagem 1 %32
    • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
  11. JBL Pulse 3 Charging Port Replacement, LED Light Display: passo 12, imagem 1 %32 JBL Pulse 3 Charging Port Replacement, LED Light Display: passo 12, imagem 2 %32 JBL Pulse 3 Charging Port Replacement, LED Light Display: passo 12, imagem 3 %32
    • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
    • Pull the LED light display off of the JBL Pulse 3 base.
  12. JBL Pulse 3 Charging Port Replacement: passo 13, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 13, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to pull the five connections off of the LED light display.
  13. JBL Pulse 3 Charging Port Replacement, Motherboard: passo 14, imagem 1 %32 JBL Pulse 3 Charging Port Replacement, Motherboard: passo 14, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the two black 8mm screws on the bottom of the LED light display.
  14. JBL Pulse 3 Charging Port Replacement: passo 15, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 15, imagem 2 %32 JBL Pulse 3 Charging Port Replacement: passo 15, imagem 3 %32
    • Pull out the motherboard slightly from the LED light display as shown. Using tweezers, unplug the three connections attached to the motherboard.
  15. JBL Pulse 3 Charging Port Replacement: passo 16, imagem 1 %32
    • Pull the rest of the motherboard out from the LED light display.
    • Using wire cutters, snip the black wire connecting to the base of the JBL Pulse 3 at the base of the motherboard. The motherboard should now be removed from the JBL Pulse 3.
  16. JBL Pulse 3 Charging Port Replacement, Speaker: passo 17, imagem 1 %32 JBL Pulse 3 Charging Port Replacement, Speaker: passo 17, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove the four 10mm screws on the corner of the speaker on the side of the base of the JBL Pulse 3.
  17. JBL Pulse 3 Charging Port Replacement: passo 18, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 18, imagem 2 %32
    • Pull out the speaker and cut the black and red wire with wire cutters. The speaker should now be removed from the JBL Pulse 3.
  18. JBL Pulse 3 Charging Port Replacement, Charging Port: passo 19, imagem 1 %32 JBL Pulse 3 Charging Port Replacement, Charging Port: passo 19, imagem 2 %32
    • Repeat the steps to take out all three speakers on the base of the JBL Pulse 3.
    • Using a Phillips #0 screwdriver, remove the 6 mm screw under each of the three speakers around the base of the JBL Pulse 3.
  19. JBL Pulse 3 Charging Port Replacement: passo 20, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 20, imagem 2 %32
    • Grab the outside of the JBL Pulse 3 at the bottom and pull outward until the outside button cover comes off.
  20. JBL Pulse 3 Charging Port Replacement: passo 21, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 21, imagem 2 %32
    • Disconnect the two connections from the inside side of the base of the JBL Pulse 3 by pushing on the wire with your index finger in the opposite direction of the connection.
  21. JBL Pulse 3 Charging Port Replacement: passo 22, imagem 1 %32 JBL Pulse 3 Charging Port Replacement: passo 22, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the four 10mm screws by the push buttons on the side of the base of the JBL Pulse 3.
  22. JBL Pulse 3 Charging Port Replacement: passo 23, imagem 1 %32
    • Pull off the inside button cover with the attached charging port. The charging port should now be removed.
Conclusão
6 outras pessoas executaram este guia.
5Comentários do guia
And how to put it back with cut cable?
Robert Rpunkt - Responder Compartilhar
Good very good
Shadow Takeshi - Responder Compartilhar
I've done a teardown and was able to access the charging terminal without cutting any wires. I didn't have a replacement, so I just put it back together hoping that cleaning it would work. Didn't work.
Beresford Crowder - Responder Compartilhar
Yeah its obvious they need to use a C type port they aren't as easy to tear up
Lloyd Mars - Responder Compartilhar
You do not have to tear it completely down unless I have a newer version after you take the speaker grill out from around the unit the thin black skeleton like gram that stiffened the grill will actually unclip from the unit with a hook tool or a ice pick that's been heated up and put a slight bend in it take your time because you can break the frame but even if you do its what they make jb weld and gorilla glue for I broke mine but went back together fine after letting the glue set up sprinkled some baking soda on it and made it twice as strong you've only got 4 screws this way cause they well the replacement plug for around $12 don't know why they don't go ahead and use the C type port smh when these came out they was already selling the replacement plug lol
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 30
Últimos 30 dias: 182
Ao todo: 19,281
