Ir para o conteúdo principal
JBL Flip disassembly
O que você precisa
  1. JBL Flip disassembly, JBL Flip disassembly: passo 1, imagem 1 %32 JBL Flip disassembly, JBL Flip disassembly: passo 1, imagem 2 %32 JBL Flip disassembly, JBL Flip disassembly: passo 1, imagem 3 %32
    • On the end with the buttons, remove the end cap using the flat head screwdriver to get between the rubber lining and the plastic.
    • After the cap is removed, unscrew the two 3.3mm screws using a size 1 ph screw driver.
    Pergunte ao FixBot
    Comentar
  2. JBL Flip disassembly: passo 2, imagem 1 %32 JBL Flip disassembly: passo 2, imagem 2 %32 JBL Flip disassembly: passo 2, imagem 3 %32
    • Unscrew four 3.3mm screws on each end of the JBL using a size 1 ph screw driver (8 screws total).
    Pergunte ao FixBot
    Comentar
  3. JBL Flip disassembly: passo 3, imagem 1 %32 JBL Flip disassembly: passo 3, imagem 2 %32 JBL Flip disassembly: passo 3, imagem 3 %32
    • Remove outermost white casing by gently lifting up on one side.
    • Remove two 5mm screws holding the silver back plate in place with a size 2 ph screw driver.
    • Gently lift up and remove the silver casing.
    Pergunte ao FixBot
    Comentar
  4. JBL Flip disassembly: passo 4, imagem 1 %32
    • Remove last white back plate to expose the back of the speaker cover.
    Pergunte ao FixBot
    Comentar
  5. JBL Flip disassembly: passo 5, imagem 1 %32 JBL Flip disassembly: passo 5, imagem 2 %32 JBL Flip disassembly: passo 5, imagem 3 %32
    • Pry the four tabs on each side of the speaker cover (8 tabs total).
    • Pry the two tabs on each end to remove the cover (4 tabs total).
    • Slide speaker out of metal speaker cover.
    Pergunte ao FixBot
    Comentar
  6. JBL Flip disassembly: passo 6, imagem 1 %32 JBL Flip disassembly: passo 6, imagem 2 %32 JBL Flip disassembly: passo 6, imagem 3 %32
    • Remove 5mm screw in the middle of the back of the device with a size 2 ph screw driver.
    • Unscrew the two 5mm screws on each side using a size 2 ph screwdriver.
    • Open the speaker.
    Pergunte ao FixBot
    Comentar
Conclusão
12 outras pessoas executaram este guia.
Dillon
Membro desde: 03/11/15
1.601 Reputação
Autoria de 5 guias
Equipe
4Comentários do guia
How do i take apart jbl flip 3
Ricky Tomas - Responder Compartilhar
My jbl flip 3 Bluetooth button does not function.How do I fix the problem?
Francis
fwathika - Responder Compartilhar
The charging PCB on my Flip3 is damaged and needs to be replaced. Any chance of purchasing the charging/interface module, fully populated?
I live in South Africa, and cannot find it here!
Paul M
Paul Moulang - Responder Compartilhar
The charging PCB on my JBL Flip3 is also damaged and needs to be replaced. Any chance of purchasing the charging/interface module?
I live in Pune - Maharashtra in India and cannot find a good reliable service station for JBL speakers here!
Suresh Karve
Suresh Karve - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 101
Ao todo: 23,723
