Ir para o conteúdo principal
JBL Flip Battery Replacement
O que você precisa
  1. JBL Flip Battery Replacement, JBL Flip disassembly: passo 1, imagem 1 %32 JBL Flip Battery Replacement, JBL Flip disassembly: passo 1, imagem 2 %32 JBL Flip Battery Replacement, JBL Flip disassembly: passo 1, imagem 3 %32
    • On the end with the buttons, remove the end cap using the flat head screwdriver to get between the rubber lining and the plastic.
    • After the cap is removed, unscrew the two 3.3mm screws using a size 1 ph screw driver.
    Pergunte ao FixBot
    Comentar
  2. JBL Flip Battery Replacement: passo 2, imagem 1 %32 JBL Flip Battery Replacement: passo 2, imagem 2 %32 JBL Flip Battery Replacement: passo 2, imagem 3 %32
    • Unscrew four 3.3mm screws on each end of the JBL using a size 1 ph screw driver (8 screws total).
    Pergunte ao FixBot
    Comentar
  3. JBL Flip Battery Replacement: passo 3, imagem 1 %32 JBL Flip Battery Replacement: passo 3, imagem 2 %32 JBL Flip Battery Replacement: passo 3, imagem 3 %32
    • Remove outermost white casing by gently lifting up on one side.
    • Remove two 5mm screws holding the silver back plate in place with a size 2 ph screw driver.
    • Gently lift up and remove the silver casing.
    Pergunte ao FixBot
    Comentar
  4. JBL Flip Battery Replacement: passo 4, imagem 1 %32
    • Remove last white back plate to expose the back of the speaker cover.
    Pergunte ao FixBot
    Comentar
  5. JBL Flip Battery Replacement: passo 5, imagem 1 %32 JBL Flip Battery Replacement: passo 5, imagem 2 %32 JBL Flip Battery Replacement: passo 5, imagem 3 %32
    • Pry the four tabs on each side of the speaker cover (8 tabs total).
    • Pry the two tabs on each end to remove the cover (4 tabs total).
    • Slide speaker out of metal speaker cover.
    Pergunte ao FixBot
    Comentar
  6. JBL Flip Battery Replacement: passo 6, imagem 1 %32 JBL Flip Battery Replacement: passo 6, imagem 2 %32 JBL Flip Battery Replacement: passo 6, imagem 3 %32
    • Remove 5mm screw in the middle of the back of the device with a size 2 ph screw driver.
    • Unscrew the two 5mm screws on each side using a size 2 ph screwdriver.
    • Open the speaker.
    Pergunte ao FixBot
    Comentar
  7. JBL Flip Battery Replacement, Battery: passo 7, imagem 1 %32 JBL Flip Battery Replacement, Battery: passo 7, imagem 2 %32
    • Slowly peel the motherboard away from the black glue on the underside.
    • Make sure the battery below the motherboard is turned off before proceeding.
    Pergunte ao FixBot
    Comentar
  8. JBL Flip Battery Replacement: passo 8, imagem 1 %32 JBL Flip Battery Replacement: passo 8, imagem 2 %32
    • Push brown tab up and gently pull connector out.
    Pergunte ao FixBot
    Comentar
  9. JBL Flip Battery Replacement: passo 9, imagem 1 %32 JBL Flip Battery Replacement: passo 9, imagem 2 %32 JBL Flip Battery Replacement: passo 9, imagem 3 %32
    • Remove the first two connectors on the underside of the motherboard.
    Pergunte ao FixBot
    Comentar
  10. JBL Flip Battery Replacement: passo 10, imagem 1 %32 JBL Flip Battery Replacement: passo 10, imagem 2 %32 JBL Flip Battery Replacement: passo 10, imagem 3 %32
    • Remove last connector.
    • Remove battery and replace.
    Pergunte ao FixBot
    Comentar
Conclusão
24 outras pessoas executaram este guia.
Dillon
Membro desde: 03/11/15
1.601 Reputação
Autoria de 5 guias
Equipe
52Comentários do guia
Excellent tutorial. Very detailed and helpful pictures.
Do you know what the part number and where it can be purchased?
Thanks!
Li V Xi - Responder Compartilhar
I also want to know about the battery specs
ravimohansairam Krishna - Responder Compartilhar
https://www.youtube.com/watch?v=apF4qT3e...
Follow this video tutorial. this will help you definitely
danish - Responder Compartilhar
Mine is not working anymore and I suspect that the battery is not charging. I´ve checked the battery and its code is AEC653055-2Pwith rating 3,7V 2000 mAh. It has 3 cables: red, yellow and black. I´ve used a voltage meetering to check if there some charge coming from and it had 4,0 VDC. So, probably the problem related to my device is with the battery, because it´s not charging. Anyone else had this same issue?
Marcio Michel - Responder Compartilhar
hey. i had the same problem with the battery of JBL flip. and i fixed it. Complete video tutorial is here :)
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 126
Ao todo: 105,862
