Ir para o conteúdo principal
JBL Flip 4 Controls Board Replacement
O que você precisa
  1. JBL Flip 4 Controls Board Replacement, Controls Board: passo 1, imagem 1 %32 JBL Flip 4 Controls Board Replacement, Controls Board: passo 1, imagem 2 %32 JBL Flip 4 Controls Board Replacement, Controls Board: passo 1, imagem 3 %32
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
    • Pull off the cover off with your thumbs.
    Pergunte ao FixBot
    Comentar
  2. JBL Flip 4 Controls Board Replacement: passo 2, imagem 1 %32 JBL Flip 4 Controls Board Replacement: passo 2, imagem 2 %32 JBL Flip 4 Controls Board Replacement: passo 2, imagem 3 %32
    • Insert the plastic opening tool under the clear rubber cover over the button control board.
    • Pry up the cover using the opening tool.
    • The cover is glued on so it will take some force to pry up.
    Pergunte ao FixBot
    Comentar
  3. JBL Flip 4 Controls Board Replacement: passo 3, imagem 1 %32 JBL Flip 4 Controls Board Replacement: passo 3, imagem 2 %32
    • Pry up the button control board by inserting the metal spudger underneath both sides of the board.
    • Try not to damage the green control board while using the metal tools.
    • The control board is glued down as well, so you will need to use some force.
    Pergunte ao FixBot
    Comentar
  4. JBL Flip 4 Controls Board Replacement: passo 4, imagem 1 %32
    • Once the board is partially unattached, pull it off using your hands.
    Pergunte ao FixBot
    Comentar
Conclusão
20 outras pessoas executaram este guia.
Philip Pang
Membro desde: 10/08/18
1.455 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S4-G3, White Fall 2018 Membro de Cal Poly, Team S4-G3, White Fall 2018
CPSU-WHITE-F18S4G3
4 Membros
Autoria de 37 guias
9Comentários do guia
Where can i buy ,control board for jbl flip 4?
Mihajlo - Responder Compartilhar
I would also be interested in buying a board (but the one at the top of the speaker, whichis holding the On and Off, as well as the JBL Connect button ). Thanks!
JPA - Responder Compartilhar
Does anyone at ifixit know where to get replacement boards?
EAN - 2/28/19
Eric - Responder Compartilhar
Id be interested in JBLmaking a minimally acceptable product
Mary Lea McTurnan - Responder Compartilhar
Where can I buy the ribbon cable?
Randl Manigsaca - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 54
Últimos 30 dias: 168
Ao todo: 37,308
