Ir para o conteúdo principal
JBL Flip 3 USB Chip Replacement
O que você precisa
  1. JBL Flip 3 USB Chip Replacement, USB Chip: passo 1, imagem 1 %32
    • Remove plastic outer housing using hands or a standard spudger.
    • Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
  2. JBL Flip 3 USB Chip Replacement: passo 2, imagem 1 %32
    • Carefully remove outer frame to expose the inner components of the speaker.
  3. JBL Flip 3 USB Chip Replacement: passo 3, imagem 1 %32
    • loosen the screws to remove the outer frame
  4. JBL Flip 3 USB Chip Replacement: passo 4, imagem 1 %32
    • Remove the 8 8.9mm Phillips #00 screws to unfasten the side passive drivers. Set the screws and side passive drivers aside safely.
  5. JBL Flip 3 USB Chip Replacement: passo 5, imagem 1 %32
  6. JBL Flip 3 USB Chip Replacement: passo 6, imagem 1 %32 JBL Flip 3 USB Chip Replacement: passo 6, imagem 2 %32
    • Remove the 3 pin connector from the USB chip.
  7. JBL Flip 3 USB Chip Replacement: passo 7, imagem 1 %32
    • remove screws to expose usb port
Conclusão
49 outras pessoas executaram este guia.
College Student
Membro desde: 02/22/17
3.479 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G2, Leahy Spring 2017 Membro de USF Tampa, Team S1-G2, Leahy Spring 2017
USFT-LEAHY-S17S1G2
Membros da 5
Autoria de 17 guias
21 comentários
how can i find the part..email me at leedeen2000@yahoo.com plz
leedeen2000 - Responder
I feel that the difficulty is just because of the lack of detail on the instructions. I also need to find the part, but where do I get it? I searched on eBay, Amazon and got nothing. That means that I have to scavenge this part from another one?
rodri.mendoza.t - Responder
i already got step 5, but i need know how i can get the replacement ? Any idea ?
PabloM - Responder
Looking for the part 2…
Daniel Brockbank - Responder
Looking for the same thing…
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 78
Últimos 30 dias: 308
Duração total: 61,347
