Ir para o conteúdo principal
JBL Flip 3 Front Active Driver Replacement
O que você precisa
  1. JBL Flip 3 Front Active Driver Replacement, Front Active Driver: passo 1, imagem 1 %32
    • Remove plastic outer housing using hands or a standard spudger.
  2. JBL Flip 3 Front Active Driver Replacement: passo 2, imagem 1 %32
    • Using your hands, carefully remove outer housing and frame to expose the internal workings of the speaker.
  3. JBL Flip 3 Front Active Driver Replacement: passo 3, imagem 1 %32
    • Remove the 8.9mm Phillips #00 screws on each corner of the driver to be replaced. There are four screws per driver. Be sure to set the screws somewhere safe to ensure they aren’t lost.
  4. JBL Flip 3 Front Active Driver Replacement: passo 4, imagem 1 %32
    • Remove the 3-pin connector from motherboard.
Conclusão
16 outras pessoas executaram este guia.
College Student
Membro desde: 02/22/17
3.512 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G2, Leahy Spring 2017 Membro de USF Tampa, Team S1-G2, Leahy Spring 2017
USFT-LEAHY-S17S1G2
Membros da 5
Autoria de 18 guias
7 comentários
where did you source the drivers from?
Rashid Saad Siddiqui - Responder
hi my flip 3 1 speaker is have give the problem thats not give the clear voice , so i want to change the parts can u help me i am where to buy this parts
manu - Responder
I too want to know where you can buy new drivers. Can't find them online so far...
Johannes - Responder
i need help getting the front speakers only where would i get them???
brian ortiz - Responder
Sir
my flip 3 Both speaker is have give the problem thats not give the clear voice , so i want to change the parts can u help me i am where to buy this parts
Anil Kumar Hembrom - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 10
Últimos 30 dias: 51
Duração total: 19,927
