Introdução
Within this guide, the user will learn how to replace the Bluetooth antenna.
O que você precisa
Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
Using the classic spudger, get underneath the black tape strips found on both side of the device.
After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
Separate the antenna off the plastic wall of the speaker by wedging it with the a spudger.
