Ir para o conteúdo principal
JBL Clip 3 Speaker Grill Replacement
O que você precisa
  1. JBL Clip 3 Speaker Grill Replacement, Speaker Grill: passo 1, imagem 1 %32 JBL Clip 3 Speaker Grill Replacement, Speaker Grill: passo 1, imagem 2 %32
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
Conclusão
3 outras pessoas executaram este guia.
Tyler Molden
Membro desde: 03/28/22
492 Reputação
Autoria de 4 guias
Equipe
3Comentários do guia
I need a replacement grill for my CLIP3 bluetooth speaker. do you know where I can get ione?
kymfaull@gmail.com
K Faull - Responder
You can get one from DubzzDesign.com He makes pretty decent 3D printed replacements.
Tom W - Responder
Is there a way to buy an oem one?
Josue - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 76
Ao todo: 2,974
