Ir para o conteúdo principal
JBL Clip 3 Motherboard Replacement
O que você precisa
  1. JBL Clip 3 Motherboard Replacement, Speaker Grill: passo 1, imagem 1 %32 JBL Clip 3 Motherboard Replacement, Speaker Grill: passo 1, imagem 2 %32
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Motherboard Replacement, Speaker Housing: passo 2, imagem 1 %32 JBL Clip 3 Motherboard Replacement, Speaker Housing: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Motherboard Replacement: passo 3, imagem 1 %32
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Motherboard Replacement: passo 4, imagem 1 %32 JBL Clip 3 Motherboard Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
  5. JBL Clip 3 Motherboard Replacement, Carabiner Clip: passo 5, imagem 1 %32 JBL Clip 3 Motherboard Replacement, Carabiner Clip: passo 5, imagem 2 %32
    • Lift the metal carabiner clip from the speaker housing.
    • They are not glued together and should separate easily.
    • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
  6. JBL Clip 3 Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 JBL Clip 3 Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    Comprar
    • Use a pair of tweezers to release the two cable connections from the motherboard.
    • The wires connecting to the battery are not very long, so be careful when removing them.
  7. JBL Clip 3 Motherboard Replacement: passo 7, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the four screws.
  8. JBL Clip 3 Motherboard Replacement: passo 8, imagem 1 %32 JBL Clip 3 Motherboard Replacement: passo 8, imagem 2 %32
    • Lift the motherboard away from the speaker housing.
    • Desolder the two contact points.
Conclusão
Uma outra pessoa concluiu este guia.
Tyler Molden
Membro desde: 03/28/22
465 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 1-5, Petersen Spring 2022 Membro de UMass Dartmouth, Team 1-5, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G5
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 24
Duração total: 653
