Ir para o conteúdo principal
JBL Clip 3 Battery Replacement
O que você precisa
  1. JBL Clip 3 Battery Replacement, Speaker Grill: passo 1, imagem 1 %32 JBL Clip 3 Battery Replacement, Speaker Grill: passo 1, imagem 2 %32
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
    Pergunte ao FixBot
    Comentar
  2. JBL Clip 3 Battery Replacement, Speaker Housing: passo 2, imagem 1 %32 JBL Clip 3 Battery Replacement, Speaker Housing: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
    Pergunte ao FixBot
    Comentar
  3. JBL Clip 3 Battery Replacement: passo 3, imagem 1 %32
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
    Pergunte ao FixBot
    Comentar
  4. JBL Clip 3 Battery Replacement: passo 4, imagem 1 %32 JBL Clip 3 Battery Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
    Pergunte ao FixBot
    Comentar
  5. JBL Clip 3 Battery Replacement, Carabiner Clip: passo 5, imagem 1 %32 JBL Clip 3 Battery Replacement, Carabiner Clip: passo 5, imagem 2 %32
    • Lift the metal carabiner clip from the speaker housing.
    • They are not glued together and should separate easily.
    • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
    Pergunte ao FixBot
    Comentar
  6. JBL Clip 3 Battery Replacement, Speaker Battery: passo 6, imagem 1 %32 JBL Clip 3 Battery Replacement, Speaker Battery: passo 6, imagem 2 %32
    • Use a pair of tweezers to lift the two cable connectors from their motherboard sockets.
    • The wires connecting to the battery are not very long, so be careful when removing them.
    Pergunte ao FixBot
    Comentar
  7. JBL Clip 3 Battery Replacement: passo 7, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the four screws that secure the motherboard.
    Pergunte ao FixBot
    Comentar
  8. JBL Clip 3 Battery Replacement: passo 8, imagem 1 %32
    • Gently lift the motherboard away from the speaker housing.
    • Take care not to damage the soldered connections when lifting the motherboard.
    Pergunte ao FixBot
    Comentar
  9. JBL Clip 3 Battery Replacement: passo 9, imagem 1 %32 JBL Clip 3 Battery Replacement: passo 9, imagem 2 %32
    • Use an opening tool to carefully pry your way around the battery, slowly lifting it off of the epoxy until it fully releases.
    • Avoid puncturing or bending the battery. It is a Lithium cell, so there is a bit of risk involved when completing this step. Be careful and patient, and there will not be any complications.
    • During reassembly, remember to superglue the new battery back into place.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Kyle Montague
Membro desde: 03/28/22
265 Reputação
Autoria de 2 guias
Equipe
3Comentários do guia
Thanks, but unless I missed something I don't see the recommended battery to replace with (only that it's a 1000mAh). Under "what you need" there's no mention of battery.
B.Bender - Responder Compartilhar
Amazon and others sell them. Just Google "JBL Clip 3 battery for sale". Price varies widely.
CalTee - Responder Compartilhar
Thank you - very helpful guide! Was able to replace my battery with no issues.
JB Zorg - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 32
Últimos 30 dias: 167
Ao todo: 10,968
