Introdução
The motherboard of the the JBL Clip 2 is the central unit that allows the unit to have all of it's different functions. The device will be taken apart and the motherboard will be removed and replaced.
O que você precisa
Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
The motherboard is now exposed, and to extract it you must now desoder the eight connection points to the battery, audio AUX cord, and the Mic.
If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
