Ir para o conteúdo principal
JBL Clip 2 Audio AUX Cord Replacement
O que você precisa
  1. JBL Clip 2 Audio AUX Cord Replacement, Audio AUX Cord: passo 1, imagem 1 %32
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Audio AUX Cord Replacement: passo 2, imagem 1 %32
    • There will be six 3 mm T8 screws under the cap, remove these six screws. Save
    • If you are not trying to replace the speaker please ignore the two middle 3 mm T8 screws during this procedure.
  3. JBL Clip 2 Audio AUX Cord Replacement: passo 3, imagem 1 %32
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Audio AUX Cord Replacement: passo 4, imagem 1 %32
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
  5. JBL Clip 2 Audio AUX Cord Replacement: passo 5, imagem 1 %32
    • There will be four 3 mm T8 screws holding the motherboard in place, remove these four screws.
  6. JBL Clip 2 Audio AUX Cord Replacement: passo 6, imagem 1 %32
Conclusão
3 outras pessoas executaram este guia.
Michael Hong
Membro desde: 02/01/17
1.014 Reputação
Autoria de 5 guias
Equipe
UW Tacoma, Team 2-2, Rose Winter 2017 Membro de UW Tacoma, Team 2-2, Rose Winter 2017
UWT-ROSE-W17S2G2
Membros da 4
Autoria de 7 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 27
Duração total: 3,610
