Ir para o conteúdo principal
JBL Charge Button Membrane Replacement
O que você precisa
  1. JBL Charge Button Membrane Replacement, Disassembling JBL Charge Casing: passo 1, imagem 1 %32 JBL Charge Button Membrane Replacement, Disassembling JBL Charge Casing: passo 1, imagem 2 %32 JBL Charge Button Membrane Replacement, Disassembling JBL Charge Casing: passo 1, imagem 3 %32
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
  2. JBL Charge Button Membrane Replacement: passo 2, imagem 1 %32 JBL Charge Button Membrane Replacement: passo 2, imagem 2 %32
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
  3. JBL Charge Button Membrane Replacement: passo 3, imagem 1 %32 JBL Charge Button Membrane Replacement: passo 3, imagem 2 %32
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
  4. JBL Charge Button Membrane Replacement: passo 4, imagem 1 %32 JBL Charge Button Membrane Replacement: passo 4, imagem 2 %32
    • Use a spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
  5. JBL Charge Button Membrane Replacement: passo 5, imagem 1 %32 JBL Charge Button Membrane Replacement: passo 5, imagem 2 %32
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
  6. JBL Charge Button Membrane Replacement: passo 6, imagem 1 %32 JBL Charge Button Membrane Replacement: passo 6, imagem 2 %32
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
  7. JBL Charge Button Membrane Replacement: passo 7, imagem 1 %32 JBL Charge Button Membrane Replacement: passo 7, imagem 2 %32
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
  8. JBL Charge Button Membrane Replacement, Motherboard: passo 8, imagem 1 %32
    • Remove the 9 mm Phillips screw in the corner of the motherboard.
  9. JBL Charge Button Membrane Replacement: passo 9, imagem 1 %32 JBL Charge Button Membrane Replacement: passo 9, imagem 2 %32
    • Remove the motherboard from the casing by lifting the corner of the board out of the device.
    • If the motherboard won't budge, be sure that the square component on the bottom of the motherboard clears the edge of the speaker.
    • During reassembly, make sure the motherboard is fully installed and not sticking up past its original position, as this could damage the motherboard.
  10. JBL Charge Button Membrane Replacement: passo 10, imagem 1 %32
    • Disconnect the two white connectors from the bottom of the motherboard.
  11. JBL Charge Button Membrane Replacement: passo 11, imagem 1 %32 JBL Charge Button Membrane Replacement: passo 11, imagem 2 %32
    • Pull down on the black clip holding the ribbon cable in place.
    • Pull the ribbon cable from the connector using the blue tab.
    • Remove the motherboard from the device.
  12. JBL Charge Button Membrane Replacement, Button Membrane: passo 12, imagem 1 %32
    • Locate the buttons on top of the device. Peel the white piece of tape located along the side of this button membrane.
  13. JBL Charge Button Membrane Replacement: passo 13, imagem 1 %32
    • Gently pull out the button membrane. You should not expect much resistance.
Conclusão
4 outras pessoas executaram este guia.
Jake Bertholf
Membro desde: 04/01/15
366 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 12-1, Lancaster Spring 2015 Membro de Cal Poly, Team 12-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G1
Membros da 5
Autoria de 11 guias
2 comentários
conseguiste el boton de repuesto?
Mario A Vargas S - Responder
Por favor, disculpe mis errores:
"No puedo encontrar un nuevo reemplazo. Compra uno roto. Utilice el botón de la que se rompe."
Joe Durand -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 9,516
