Ir para o conteúdo principal
JBL Charge 4 Speaker Replacement
O que você precisa
  1. JBL Charge 4 Speaker Replacement, Speaker Grill: passo 1, imagem 1 %32
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Speaker Replacement: passo 2, imagem 1 %32 JBL Charge 4 Speaker Replacement: passo 2, imagem 2 %32
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Speaker Replacement: passo 3, imagem 1 %32
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Speaker Replacement, Passive Bass Radiators: passo 4, imagem 1 %32 JBL Charge 4 Speaker Replacement, Passive Bass Radiators: passo 4, imagem 2 %32
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Speaker Replacement: passo 5, imagem 1 %32 JBL Charge 4 Speaker Replacement: passo 5, imagem 2 %32
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
  6. JBL Charge 4 Speaker Replacement, Speaker: passo 6, imagem 1 %32 JBL Charge 4 Speaker Replacement, Speaker: passo 6, imagem 2 %32
    • Flip the device so that the speaker faces you.
    • Remove the four 8mm Phillips #1 screws.
  7. JBL Charge 4 Speaker Replacement: passo 7, imagem 1 %32
    • Gently pull out the speaker.
  8. JBL Charge 4 Speaker Replacement: passo 8, imagem 1 %32 JBL Charge 4 Speaker Replacement: passo 8, imagem 2 %32
    • Desolder the red and black wires.
    • A guide for soldering and desoldering can be found here.
Conclusão
10 outras pessoas executaram este guia.
Rohith Dara
Membro desde: 01/24/19
357 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S1-G1, White Winter 2019 Membro de Cal Poly, Team S1-G1, White Winter 2019
CPSU-WHITE-W19S1G1
Membros da 4
Autoria de 26 guias
11 comentários
Perfect - But where to get the replacement speaker ??? I’ve searched whole web. Please give me the info about replacement speaker diaphragm. Regards, T
Tadej Tomašič - Responder
Jbl charge 4 Led indicator board G ribbon cable authentic
carlos maltez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 42
Últimos 30 dias: 197
Duração total: 22,614
