Ir para o conteúdo principal
JBL Charge 4 Motherboard Replacement
O que você precisa
  1. JBL Charge 4 Motherboard Replacement, Speaker Grill: passo 1, imagem 1 %32
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Motherboard Replacement: passo 2, imagem 1 %32 JBL Charge 4 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Motherboard Replacement: passo 3, imagem 1 %32
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Motherboard Replacement, Passive Bass Radiators: passo 4, imagem 1 %32 JBL Charge 4 Motherboard Replacement, Passive Bass Radiators: passo 4, imagem 2 %32
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Motherboard Replacement: passo 5, imagem 1 %32 JBL Charge 4 Motherboard Replacement: passo 5, imagem 2 %32
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
  6. JBL Charge 4 Motherboard Replacement, Battery: passo 6, imagem 1 %32 JBL Charge 4 Motherboard Replacement, Battery: passo 6, imagem 2 %32
    • Remove the two 6mm Phillips #0 screws on the front side of the port bay cover.
  7. JBL Charge 4 Motherboard Replacement: passo 7, imagem 1 %32
    • Gently slide the cover back and off the hooks.
    • Remove the port bay cover.
  8. JBL Charge 4 Motherboard Replacement: passo 8, imagem 1 %32 JBL Charge 4 Motherboard Replacement: passo 8, imagem 2 %32 JBL Charge 4 Motherboard Replacement: passo 8, imagem 3 %32
    • Remove the two 6mm Phillips #0 screws.
    • Remove the four 8mm Phillips #0 screws.
  9. JBL Charge 4 Motherboard Replacement: passo 9, imagem 1 %32
    • Lift up the battery cover.
  10. JBL Charge 4 Motherboard Replacement: passo 10, imagem 1 %32 JBL Charge 4 Motherboard Replacement: passo 10, imagem 2 %32 JBL Charge 4 Motherboard Replacement: passo 10, imagem 3 %32
    • Remove the sticky tape to expose the white ribbon cable ZIF connector.
    • Flip up the black locking flap on the ZIF connector with the tip of a spudger or your fingernail to release the cable.
    • Remove the white ribbon cable from the battery cover and place the cover to the side.
  11. JBL Charge 4 Motherboard Replacement: passo 11, imagem 1 %32 JBL Charge 4 Motherboard Replacement: passo 11, imagem 2 %32
    • Remove the battery from the battery socket by gently pulling on it.
  12. JBL Charge 4 Motherboard Replacement: passo 12, imagem 1 %32 JBL Charge 4 Motherboard Replacement: passo 12, imagem 2 %32 JBL Charge 4 Motherboard Replacement: passo 12, imagem 3 %32
    • Pull out the battery enough to expose the battery's wire connector.
    • Push down on the white tab and gently pull out the battery-device connector.
  13. JBL Charge 4 Motherboard Replacement, Speaker: passo 13, imagem 1 %32 JBL Charge 4 Motherboard Replacement, Speaker: passo 13, imagem 2 %32
    • Flip the device so that the speaker faces you.
    • Remove the four 8mm Phillips #1 screws.
  14. JBL Charge 4 Motherboard Replacement: passo 14, imagem 1 %32
    • Gently pull out the speaker.
  15. JBL Charge 4 Motherboard Replacement: passo 15, imagem 1 %32 JBL Charge 4 Motherboard Replacement: passo 15, imagem 2 %32
    • Desolder the red and black wires.
    • A guide for soldering and desoldering can be found here.
  16. JBL Charge 4 Motherboard Replacement, Motherboard: passo 16, imagem 1 %32 JBL Charge 4 Motherboard Replacement, Motherboard: passo 16, imagem 2 %32 JBL Charge 4 Motherboard Replacement, Motherboard: passo 16, imagem 3 %32
    • Remove the wire harness coming from the port bay on the left side of the motherboard by gently lifting the connector from its housing.
    • Remove the white ribbon cable from the ZIF connector by lifting the black locking flap on the connector with a spudger or your fingernail.
  17. JBL Charge 4 Motherboard Replacement: passo 17, imagem 1 %32 JBL Charge 4 Motherboard Replacement: passo 17, imagem 2 %32
    • Remove the ground cable harness next to the speaker wire by gentling pulling it from the connector.
  18. JBL Charge 4 Motherboard Replacement: passo 18, imagem 1 %32 JBL Charge 4 Motherboard Replacement: passo 18, imagem 2 %32
    • Flip the speaker around to the other side.
    • Remove the wiring harness leading to the port bay by pressing down on the tab and gently pulling the harness from the connector.
  19. JBL Charge 4 Motherboard Replacement: passo 19, imagem 1 %32 JBL Charge 4 Motherboard Replacement: passo 19, imagem 2 %32 JBL Charge 4 Motherboard Replacement: passo 19, imagem 3 %32
    • Push the motherboard from either side of the housing along its tracks.
    • Pull out the motherboard from the speaker housing.
    • When putting the motherboard back in the housing, ensure that it is between the two tracks on the top side of the speaker.
Conclusão
11 outras pessoas executaram este guia.
Zachary Colwell
Membro desde: 01/24/19
1.914 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S1-G1, White Winter 2019 Membro de Cal Poly, Team S1-G1, White Winter 2019
CPSU-WHITE-W19S1G1
Membros da 4
Autoria de 26 guias
4 comentários
Where i could buy a replacement motherboard for jbl charge 4?thank you.
bbt8mikael_06 - Responder
This guide has a vital flaw. Just look at the loose wire cause by a broken solder in image 16!
PAJ 101 - Responder
that's the antenna cable which was pulled out of the connector. The step of popping the antenna connector out is missing.
Dan Glogoveanu -
from where i buy or replace the motherboard of jbl charge 4?
Aman Bisht - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 41
Últimos 30 dias: 215
Duração total: 12,447
