Ir para o conteúdo principal
JBL Charge 4 Buttons Replacement
O que você precisa
  1. JBL Charge 4 Buttons Replacement, Speaker Grill: passo 1, imagem 1 %32
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
    Pergunte ao FixBot
    Comentar
  2. JBL Charge 4 Buttons Replacement: passo 2, imagem 1 %32 JBL Charge 4 Buttons Replacement: passo 2, imagem 2 %32
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
    Pergunte ao FixBot
    Comentar
  3. JBL Charge 4 Buttons Replacement: passo 3, imagem 1 %32
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
    Pergunte ao FixBot
    Comentar
  4. JBL Charge 4 Buttons Replacement, Passive Bass Radiators: passo 4, imagem 1 %32 JBL Charge 4 Buttons Replacement, Passive Bass Radiators: passo 4, imagem 2 %32
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
    Pergunte ao FixBot
    Comentar
  5. JBL Charge 4 Buttons Replacement: passo 5, imagem 1 %32 JBL Charge 4 Buttons Replacement: passo 5, imagem 2 %32
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
    Pergunte ao FixBot
    Comentar
  6. JBL Charge 4 Buttons Replacement, Buttons: passo 6, imagem 1 %32 JBL Charge 4 Buttons Replacement, Buttons: passo 6, imagem 2 %32 JBL Charge 4 Buttons Replacement, Buttons: passo 6, imagem 3 %32
    • Lift up the tape covering the button control board ZIF connector on the left side of the motherboard.
    • Flip up the black locking flap on the ZIF connector with the tip of the spudger or your fingernail to release the white ribbon cable.
    Pergunte ao FixBot
    Comentar
  7. JBL Charge 4 Buttons Replacement: passo 7, imagem 1 %32 JBL Charge 4 Buttons Replacement: passo 7, imagem 2 %32
    • Flip the speaker over so the buttons are on the top.
    • Using the plastic opening tool, pry up the rubber covering the button control board from the adhesive.
    • Remove the cover and set to the side.
    • By removing the rubber cover and the control board you are breaking adhesives that may result in the speaker no longer being waterproof.
    Pergunte ao FixBot
    Comentar
  8. JBL Charge 4 Buttons Replacement: passo 8, imagem 1 %32 JBL Charge 4 Buttons Replacement: passo 8, imagem 2 %32 JBL Charge 4 Buttons Replacement: passo 8, imagem 3 %32
    • Using the plastic opening tool, pry up the button control board from the adhesive.
    • This will require cutting the adhesive surrounding the board.
    • Gently lift off the button control board feeding the ribbon cable through the slot.
    • When installing a new button control board, make sure to clean all the adhesive residue left by the old board.
    Pergunte ao FixBot
    Comentar
Conclusão
14 outras pessoas executaram este guia.
Zachary Colwell
Membro desde: 01/24/19
2.189 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S1-G1, White Winter 2019 Membro de Cal Poly, Team S1-G1, White Winter 2019
CPSU-WHITE-W19S1G1
4 Membros
Autoria de 29 guias
2Comentários do guia
Hi - where can I buy the button control board?
Rahman Sayeed - Responder Compartilhar
How do I boot up JBL CHARGE 4
sashajankovic527 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 51
Últimos 30 dias: 171
Ao todo: 26,906
