Ir para o conteúdo principal
JBL Charge 4 Battery Replacement
O que você precisa
  1. JBL Charge 4 Battery Replacement, Speaker Grill: passo 1, imagem 1 %32
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
    Pergunte ao FixBot
    Comentar
  2. JBL Charge 4 Battery Replacement: passo 2, imagem 1 %32 JBL Charge 4 Battery Replacement: passo 2, imagem 2 %32
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
    Pergunte ao FixBot
    Comentar
  3. JBL Charge 4 Battery Replacement: passo 3, imagem 1 %32
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
    Pergunte ao FixBot
    Comentar
  4. JBL Charge 4 Battery Replacement, Passive Bass Radiators: passo 4, imagem 1 %32 JBL Charge 4 Battery Replacement, Passive Bass Radiators: passo 4, imagem 2 %32
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
    Pergunte ao FixBot
    Comentar
  5. JBL Charge 4 Battery Replacement: passo 5, imagem 1 %32 JBL Charge 4 Battery Replacement: passo 5, imagem 2 %32
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
    Pergunte ao FixBot
    Comentar
  6. JBL Charge 4 Battery Replacement, Battery: passo 6, imagem 1 %32 JBL Charge 4 Battery Replacement, Battery: passo 6, imagem 2 %32
    • Remove the two 6mm Phillips #0 screws on the front side of the port bay cover.
    Pergunte ao FixBot
    Comentar
  7. JBL Charge 4 Battery Replacement: passo 7, imagem 1 %32
    • Gently slide the cover back and off the hooks.
    • Remove the port bay cover.
    Pergunte ao FixBot
    Comentar
  8. JBL Charge 4 Battery Replacement: passo 8, imagem 1 %32 JBL Charge 4 Battery Replacement: passo 8, imagem 2 %32 JBL Charge 4 Battery Replacement: passo 8, imagem 3 %32
    • Remove the two 6mm Phillips #0 screws.
    • Remove the four 8mm Phillips #0 screws.
    Pergunte ao FixBot
    Comentar
  9. JBL Charge 4 Battery Replacement: passo 9, imagem 1 %32
    • Lift up the battery cover.
    Pergunte ao FixBot
    Comentar
  10. JBL Charge 4 Battery Replacement: passo 10, imagem 1 %32 JBL Charge 4 Battery Replacement: passo 10, imagem 2 %32 JBL Charge 4 Battery Replacement: passo 10, imagem 3 %32
    • Remove the sticky tape to expose the white ribbon cable ZIF connector.
    • Flip up the black locking flap on the ZIF connector with the tip of a spudger or your fingernail to release the cable.
    • Remove the white ribbon cable from the battery cover and place the cover to the side.
    Pergunte ao FixBot
    Comentar
  11. JBL Charge 4 Battery Replacement: passo 11, imagem 1 %32 JBL Charge 4 Battery Replacement: passo 11, imagem 2 %32
    • Remove the battery from the battery socket by gently pulling on it.
    Pergunte ao FixBot
    Comentar
  12. JBL Charge 4 Battery Replacement: passo 12, imagem 1 %32 JBL Charge 4 Battery Replacement: passo 12, imagem 2 %32 JBL Charge 4 Battery Replacement: passo 12, imagem 3 %32
    • Pull out the battery enough to expose the battery's wire connector.
    • Push down on the white tab and gently pull out the battery-device connector.
    Pergunte ao FixBot
    Comentar
Conclusão
29 outras pessoas executaram este guia.
Sydney Seto
Membro desde: 01/24/19
962 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S1-G1, White Winter 2019 Membro de Cal Poly, Team S1-G1, White Winter 2019
CPSU-WHITE-W19S1G1
4 Membros
Autoria de 29 guias
18Comentários do guia
Where do you buy a battery for a jbl Charge 4 ??
Matt hempel - Responder Compartilhar
Probably just cut open the blue foil around the batteries and replace them by re-soldering the electronics onto new 18650 batteries.
correct me if I’m wrong here.
Brendon Reijnders - Responder Compartilhar
If you know how to handle them and have experience with soldering them that's a yes if not those batteries are really dangerous if you don't know how to do it correctly.
Hart80 - Responder Compartilhar
Where in the !&&* do i get a battery for a bluetooth speaker. What happened to the jbl charge 4 that it even goes out???
Shani Sanders - Responder Compartilhar
My JBL charge 4 battery dead too. 9nly uses it for three months
osborne buhere - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 40
Últimos 7 dias: 310
Últimos 30 dias: 981
Ao todo: 85,585
