Introdução
If any of the three ports on your JBL Charge 3 (AUX, USB, charging) are not functioning, they may need replacing. If you wish to replace only one of the ports rather than the whole assembly, you will need to know how to solder. Follow iFixit's Soldering Guide to learn more.
O que você precisa
Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
Repeat this process for all four edges of the front cover.
Take out the four 8mm Phillips #1 screws out of the port bay cover.
Wedge your plastic opening tool around the port bay to remove it.
38 outras pessoas executaram este guia.
16Comentários do guia
Is there a place to buy an entire replacement port bay?
Found the whole assembly on line for 30 bucks. Or a usb port for five from jbl
Can u share a link? Need a new port bay!
