Ir para o conteúdo principal
JBL Charge 3 Battery Replacement
O que você precisa
  1. JBL Charge 3 Battery Replacement, Front Cover: passo 1, imagem 1 %32 JBL Charge 3 Battery Replacement, Front Cover: passo 1, imagem 2 %32 JBL Charge 3 Battery Replacement, Front Cover: passo 1, imagem 3 %32
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
    Pergunte ao FixBot
    Comentar
  2. JBL Charge 3 Battery Replacement: passo 2, imagem 1 %32
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • There are screws around the foot of the device that may need loosening to be able to unclip the other side of the cover.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
    Pergunte ao FixBot
    Comentar
  3. JBL Charge 3 Battery Replacement, Passive Radiators: passo 3, imagem 1 %32 JBL Charge 3 Battery Replacement, Passive Radiators: passo 3, imagem 2 %32 JBL Charge 3 Battery Replacement, Passive Radiators: passo 3, imagem 3 %32
    • Remove the two 8mm Phillips #1 screws from the tabs.
    • NOTE: There may be only one screw.
    Pergunte ao FixBot
    Comentar
  4. JBL Charge 3 Battery Replacement: passo 4, imagem 1 %32 JBL Charge 3 Battery Replacement: passo 4, imagem 2 %32
    • Insert the plastic opening tools underneath both tabs.
    Pergunte ao FixBot
    Comentar
  5. JBL Charge 3 Battery Replacement: passo 5, imagem 1 %32
    • Twist and pull open the passive radiator. The left radiator twists off clockwise; the right counterclockwise.
    Pergunte ao FixBot
    Comentar
  6. JBL Charge 3 Battery Replacement: passo 6, imagem 1 %32 JBL Charge 3 Battery Replacement: passo 6, imagem 2 %32
    • Repeat all previous steps for the other passive radiator.
    • NOTE: only the right radiator needs to be removed for changing the battery.
    Pergunte ao FixBot
    Comentar
  7. JBL Charge 3 Battery Replacement, Battery: passo 7, imagem 1 %32 JBL Charge 3 Battery Replacement, Battery: passo 7, imagem 2 %32 JBL Charge 3 Battery Replacement, Battery: passo 7, imagem 3 %32
    • Remove the six 8mm Phillips #1 screws from the outer battery cover.
    • Peel the outer battery cover away from the speaker housing.
    Pergunte ao FixBot
    Comentar
  8. JBL Charge 3 Battery Replacement: passo 8, imagem 1 %32 JBL Charge 3 Battery Replacement: passo 8, imagem 2 %32 JBL Charge 3 Battery Replacement: passo 8, imagem 3 %32
    • Remove the seven 8mm Phillips #1 screws from interior battery cover.
    • Remove the interior battery cover.
    Pergunte ao FixBot
    Comentar
  9. JBL Charge 3 Battery Replacement: passo 9, imagem 1 %32 JBL Charge 3 Battery Replacement: passo 9, imagem 2 %32
    • Pull gently to disconnect the bundled cable connector in the side of the speaker. This action will separate the battery from the motherboard.
    Pergunte ao FixBot
    Comentar
  10. JBL Charge 3 Battery Replacement: passo 10, imagem 1 %32
    • Pull the battery and battery cable out from their housing.
    Pergunte ao FixBot
    Comentar
Conclusão
153 outras pessoas executaram este guia.
Jack Ng
Membro desde: 10/08/18
2.434 Reputação
Autoria de 4 guias
35Comentários do guia
you legend. thank you so much! i was worried it was a seal unit!
Anthony Hilfischer - Responder Compartilhar
Super Anleitung! Hat der Akkutausch hat problemlos funktioniert!
Tomas Opmann - Responder Compartilhar
thank you so much :D
punkzmarc - Responder Compartilhar
Great Guide! Where can I get the foamy coating of the battery’s wires? Or what is the proper term?
Dom Heizmann - Responder Compartilhar
I saw one on youtube taking the one from the old battery and putting it on the new one
Dominik Spreuer - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 61
Últimos 7 dias: 497
Últimos 30 dias: 1,723
Ao todo: 270,667
