Ir para o conteúdo principal
Ivation IVWPDC20Y Display Replacement
O que você precisa
    1. Ivation IVWPDC20Y Display Replacement, Display: passo 1, imagem 1 %32
      • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
      Pergunte ao FixBot
      Comentar
    2. Ivation IVWPDC20Y Display Replacement: passo 2, imagem 1 %32
      • Apply a plastic opening tool to each of the corners and gently remove the casing
      • The front casing is held down by adhesive and may require additional work to remove
      • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
      Pergunte ao FixBot
      Comentar
    3. Ivation IVWPDC20Y Display Replacement: passo 3, imagem 1 %32
      • Remove the five silver screws from the inner casing using the PH00 screwdriver bit.
      Pergunte ao FixBot
      Comentar
    4. Ivation IVWPDC20Y Display Replacement: passo 4, imagem 1 %32
      • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit.
      • These screws are very small and easy to strip so apply consistent pressure when removing them
      Pergunte ao FixBot
      Comentar
    5. Ivation IVWPDC20Y Display Replacement: passo 5, imagem 1 %32
      • Pry off back outer casing using the black spudger or the blue prying tools.
      Pergunte ao FixBot
      Comentar
    6. Ivation IVWPDC20Y Display Replacement: passo 6, imagem 1 %32
      • Carefully remove the screen from the silver casing using a prying tool or the black spudger.
      • There is adhesive in the center of the screen, be sure not to bend it when applying pressure.
      Pergunte ao FixBot
      Comentar
    7. Ivation IVWPDC20Y Display Replacement: passo 7, imagem 1 %32
      • Using the poker end of the spudger push gently on the black pegs holding the orange tape in place.
      • Screen and orange tape should slip out as a whole.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Alex
Membro desde: 02/08/16
228 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 6-6, Eyestone Spring 2016 Membro de USF Tampa, Team 6-6, Eyestone Spring 2016
USFT-EYESTONE-S16S6G6
3 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 636
