Ir para o conteúdo principal
Instax Mini 90 Lens Unit Replacement
O que você precisa
    1. Instax Mini 90 Lens Unit Replacement, Battery: passo 1, imagem 1 %32 Instax Mini 90 Lens Unit Replacement, Battery: passo 1, imagem 2 %32
      • The battery compartment can be found on the backside of the camera. Pinpoint this compartment and focus on the right edge of the compartment gate to find the opening latch.
      Pergunte ao FixBot
      Comentar
    2. Instax Mini 90 Lens Unit Replacement: passo 2, imagem 1 %32 Instax Mini 90 Lens Unit Replacement: passo 2, imagem 2 %32
      • Pinch the latch in towards the battery compartment gate. This will release the gate and allow it to open.
      • Completely open the gate and remove from camera. Take out the battery and replace the gate.
      Pergunte ao FixBot
      Comentar
    1. Instax Mini 90 Lens Unit Replacement, Lens Unit: passo 3, imagem 1 %32 Instax Mini 90 Lens Unit Replacement, Lens Unit: passo 3, imagem 2 %32
      • Face the front side of the camera towards you. To locate the left side turn the left side of the camera towards you.
      • Take out the four screws, sized 4.75 mm, with the Phillips #000 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Instax Mini 90 Lens Unit Replacement: passo 4, imagem 1 %32 Instax Mini 90 Lens Unit Replacement: passo 4, imagem 2 %32
      • Looking at the left side, flip the top of the camera towards you to locate the top side of the camera.
      • Take out the screw sized 9.75 mm, located on top side of the camera, with a Phillips #000 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Instax Mini 90 Lens Unit Replacement: passo 5, imagem 1 %32 Instax Mini 90 Lens Unit Replacement: passo 5, imagem 2 %32
      • Looking at the top of the camera, flip the camera 180 degrees to locate the bottom side of the camera.
      • Take out the screw, sized 3.75 mm, located on the bottom side of the camera, this time with a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Instax Mini 90 Lens Unit Replacement: passo 6, imagem 1 %32 Instax Mini 90 Lens Unit Replacement: passo 6, imagem 2 %32 Instax Mini 90 Lens Unit Replacement: passo 6, imagem 3 %32
      • Remove the silver casing from the top of the camera. It is loosely clipped in and should come off easily.
      • Using a thin spudger, remove the chrome plastic cover from which the film is ejected. It is clipped onto the main body of the camera, and should come off with a sharp pull.
      • Using a thin spudger, pry off the silver casing from the bottom of the camera.
      • The bottom silver casing is clipped on tightly around the film ejection area, but is not held on by any screws or glue. Make sure to unclip it fully (this may take some force) before removing it, to avoid breaking it.
      Pergunte ao FixBot
      Comentar
    5. Instax Mini 90 Lens Unit Replacement: passo 7, imagem 1 %32
      • There is a 4.75 mm screw located above the film ejection area. Use a Phillips #000 screwdriver to remove it.
      • Using a Philips #000 screwdriver, unscrew the strap anchors from the top and bottom of the camera.
      Pergunte ao FixBot
      Comentar
    6. Instax Mini 90 Lens Unit Replacement: passo 8, imagem 1 %32 Instax Mini 90 Lens Unit Replacement: passo 8, imagem 2 %32
      • Open up the camera by releasing the latches on the top and bottom of the camera. There are 2 latches on top and 2 on the bottom. Once the two halves of the camera are unhooked, you can easily pry open the camera with your hands.
      • Set camera down on a flat surface with both sides facing up.
      • The top shutter button is connected using two thin soldered wires (black and red) to the main board. Use caution when prying the camera open.
      • Avoid touching the area around the flash capacitor (the big black cylinder) as it could result in an uncomfortable (but non-dangerous) electric shock, even with the battery removed.
      Pergunte ao FixBot
      Comentar
    7. Instax Mini 90 Lens Unit Replacement: passo 9, imagem 1 %32 Instax Mini 90 Lens Unit Replacement: passo 9, imagem 2 %32 Instax Mini 90 Lens Unit Replacement: passo 9, imagem 3 %32
      • Set aside the black, plastic loop located inside the lens cavity.
      • Use a Phillips #000 screwdriver to remove the two 3.75 mm sized screws marked in the photo.
      • Move aside the motherboard located under the top screw. Then remove the marked 3.75 mm sized screw.
      Pergunte ao FixBot
      Comentar
    8. Instax Mini 90 Lens Unit Replacement: passo 10, imagem 1 %32
      • Remove the next two screws with a Phillips #000 screwdriver. The upper screw, sized 1.75 mm, is facing in towards the center of the lens unit. The lower screw, sized 4.75 mm, is to the right of the upper screw and faces down into the camera.
      Pergunte ao FixBot
      Comentar
    9. Instax Mini 90 Lens Unit Replacement: passo 11, imagem 1 %32 Instax Mini 90 Lens Unit Replacement: passo 11, imagem 2 %32 Instax Mini 90 Lens Unit Replacement: passo 11, imagem 3 %32
      • Lift up the lens unit from the camera.
      • Push the lens unit towards you to remove it from the casing.
      • Unplug the lens unit from the case.
      Pergunte ao FixBot
      Comentar
Conclusão
9 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S2-G1, Nance Spring 2017 Membro de USF Tampa, Team S2-G1, Nance Spring 2017
USFT-NANCE-S17S2G1
4 Membros
Autoria de 12 guias
1Comentário do guia
Hey Elliott
thank you very much for your work,very useful and clear but i can’t find the lens unit on the web. Do you know where i can find it please ?
Ghislain
ghislain.perez@outlook.fr
pperez - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 22
Últimos 30 dias: 80
Ao todo: 16,544
