Introdução
This should be a fairly easy fix, since the only tool you need is a Phillips #000 screwdriver. There are no safety risks in this process, as long as you keep the camera turned off. The battery contact could have been damaged when the camera was dropped, or if the camera was not kept in a cool, clean, indoor environment. To prevent further damage to battery contact, only use the proper batteries from Fujifilm, and take caution to prevent battery leaks. Remove battery when the camera is not being used for long periods of time.
O que você precisa
The battery compartment can be found on the backside of the camera. Pinpoint this compartment and focus on the right edge of the compartment gate to find the opening latch.
Turn camera around to its backside.
Open up the back side of the camera by pushing up on the slide button. This button is located on the middle left side of the camera.
1Comentário do guia
This guide only removes the battery tray. The contacts are visible in the last pic of the last step, still in place, under the red wire
