Ir para o conteúdo principal
Instant Pot 60 EPC Circuit Board Replacement
O que você precisa
  1. Instant Pot 60 EPC Circuit Board Replacement, Circuit Board: passo 1, imagem 1 %32 Instant Pot 60 EPC Circuit Board Replacement, Circuit Board: passo 1, imagem 2 %32 Instant Pot 60 EPC Circuit Board Replacement, Circuit Board: passo 1, imagem 3 %32
    • Ensure the device is unplugged and cool before beginning.
    • Remove the lid and inner pot from the Instant Pot and turn the body upside down.
    • Remove the single Torx screw.
  2. Instant Pot 60 EPC Circuit Board Replacement: passo 2, imagem 1 %32 Instant Pot 60 EPC Circuit Board Replacement: passo 2, imagem 2 %32
    • Turn the bottom face counterclockwise and remove it.
  3. Instant Pot 60 EPC Circuit Board Replacement: passo 3, imagem 1 %32 Instant Pot 60 EPC Circuit Board Replacement: passo 3, imagem 2 %32 Instant Pot 60 EPC Circuit Board Replacement: passo 3, imagem 3 %32
    • In order to reach the circuit board you'll need to remove the secondary frame surrounding it.
    • Remove the three Phillips screws securing the frame.
    • Lift the frame, twist and set next to the body. Take care not to damage any of the attached wiring.
  4. Instant Pot 60 EPC Circuit Board Replacement: passo 4, imagem 1 %32 Instant Pot 60 EPC Circuit Board Replacement: passo 4, imagem 2 %32 Instant Pot 60 EPC Circuit Board Replacement: passo 4, imagem 3 %32
    • Depress the latch securing the red connector and disconnect it.
    • Repeat the previous bullet for the white and black connectors.
    • It can be helpful to gently rock them back and forth while pulling up.
  5. Instant Pot 60 EPC Circuit Board Replacement: passo 5, imagem 1 %32 Instant Pot 60 EPC Circuit Board Replacement: passo 5, imagem 2 %32
    • Use a Phillips screwdriver to remove the two screws holding each of the two leads in place.
  6. Instant Pot 60 EPC Circuit Board Replacement: passo 6, imagem 1 %32 Instant Pot 60 EPC Circuit Board Replacement: passo 6, imagem 2 %32
    • Gently walk the 8x1 pin connector out of its socket.
    • It may be helpful to also rock the plug side to side while pulling up.
  7. Instant Pot 60 EPC Circuit Board Replacement: passo 7, imagem 1 %32 Instant Pot 60 EPC Circuit Board Replacement: passo 7, imagem 2 %32 Instant Pot 60 EPC Circuit Board Replacement: passo 7, imagem 3 %32
    • Slide the blue sheathing up to expose the small hole in the lead.
    • Place a SIM card punch into the hole to unsecure the leads and pull them up. If a SIM card punch is not available, then a paperclip or earring should suffice.
    • Repeat for the other two leads.
  8. Instant Pot 60 EPC Circuit Board Replacement: passo 8, imagem 1 %32 Instant Pot 60 EPC Circuit Board Replacement: passo 8, imagem 2 %32
    • Pull the board up slightly to unclip it from its stand and lift from the body to remove the circuit board.
  9. Instant Pot 60 EPC Circuit Board Replacement: passo 9, imagem 1 %32
    • Instant Pot does not provide a new sensor with the device, so it will have to be purchased from a secondary source.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
4 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 20
Últimos 30 dias: 80
Ao todo: 738
