Ir para o conteúdo principal
Insignia NS-PLTPSP13 Speaker Cone Replacement
O que você precisa
  1. Insignia NS-PLTPSP13 Speaker Cone Replacement, Insignia NS-PLTPSP13 Disassembly: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to lift the corner of the mesh until a gap is created.
  2. Insignia NS-PLTPSP13 Speaker Cone Replacement: passo 2, imagem 1 %32 Insignia NS-PLTPSP13 Speaker Cone Replacement: passo 2, imagem 2 %32
    • Once there is a gap big enough, insert the metal spudger, and remove the tweezers.
  3. Insignia NS-PLTPSP13 Speaker Cone Replacement: passo 3, imagem 1 %32 Insignia NS-PLTPSP13 Speaker Cone Replacement: passo 3, imagem 2 %32 Insignia NS-PLTPSP13 Speaker Cone Replacement: passo 3, imagem 3 %32
    • Now take the size J0 JIS screwdriver to remove the seven 5 mm screws on the plastic casing of the speaker.
    • Do not forget about the 5mm screw on the backside of the speaker, it may be covered by a white sticker, and it will prevent you from removing the plastic cover.
  4. Insignia NS-PLTPSP13 Speaker Cone Replacement: passo 4, imagem 1 %32 Insignia NS-PLTPSP13 Speaker Cone Replacement: passo 4, imagem 2 %32
    • Once all seven 5mm screws are taken off use the metal spudger again to pry off the plastic casing from the speaker.
  5. Insignia NS-PLTPSP13 Speaker Cone Replacement: passo 5, imagem 1 %32 Insignia NS-PLTPSP13 Speaker Cone Replacement: passo 5, imagem 2 %32
    • To further take apart the speaker, there are also two 5mm screws on the green circuit board which keep the speaker and circuit board attached. Unscrew these with the size J0 JIS screwdriver.
  6. Insignia NS-PLTPSP13 Speaker Cone Replacement, Speaker Cone: passo 6, imagem 1 %32 Insignia NS-PLTPSP13 Speaker Cone Replacement, Speaker Cone: passo 6, imagem 2 %32
Conclusão
Colin Farragher
Membro desde: 03/21/17
101 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 368
